I bought that model from aliexpress and i think that was a bad idea.
To display works, i needed change the UTF library, because the default not works.
After a lot of working, I'm stuck in the touch.
Do you have any experience with this TFT?
Model: TFT_320QVT_9341
http://pt.aliexpress.com/item/Free-ship ... 60245.html
Description:
The new 3.2 LCD touch module,
240X320 HD resolution, with a touch of high-quality modules,
Cheap, supporting data and more, welcome to shop around!
3.2 inch touch TFT module integrated touch control IC, SD card connector, 3V regulator, resolution 240 * 320 driver IC: 9341
SSD1289IC has been discontinued for many years, has been unable to continue production, with immediate effect, 3.2-inch screen has been updated to ILI9341 drive, the same hardware structure and interface definitions, driver changes slightly, the quality is more stable. Please note that the driver update old customers. The original 3.2-inch module with PCB back of the PCB screen play is TFT_320QVT, the new 9341 driver hit the back of the module PCB screen is TFT_320QVT_9341, please old customers note that distinction.
Thanks for help.
