Forum Software Ferduino code TFT_320QVT_9341
TFT_320QVT_9341  [SOLVED]
Post Number:#1 Post Mon May 23, 2016 1:44 am
I bought that model from aliexpress and i think that was a bad idea.
To display works, i needed change the UTF library, because the default not works.
After a lot of working, I'm stuck in the touch.
Do you have any experience with this TFT?
Model: TFT_320QVT_9341
http://pt.aliexpress.com/item/Free-ship ... 60245.html
Description:
The new 3.2 LCD touch module,
240X320 HD resolution, with a touch of high-quality modules,
Cheap, supporting data and more, welcome to shop around!
3.2 inch touch TFT module integrated touch control IC, SD card connector, 3V regulator, resolution 240 * 320 driver IC: 9341
SSD1289IC has been discontinued for many years, has been unable to continue production, with immediate effect, 3.2-inch screen has been updated to ILI9341 drive, the same hardware structure and interface definitions, driver changes slightly, the quality is more stable. Please note that the driver update old customers. The original 3.2-inch module with PCB back of the PCB screen play is TFT_320QVT, the new 9341 driver hit the back of the module PCB screen is TFT_320QVT_9341, please old customers note that distinction.
Thanks for help.
Post Number:#2 Post Mon May 23, 2016 10:23 am
This TFT is not compatible with my code.
The resolution should be 400 x 240.
This TFT would be an ITDB32S but with a different touch controller. The ITDS32S uses a SSD1289 not ILI9341 I don't know if this controllers are compatible.
Try the libraries from Henning's site: http://www.rinkydinkelectronics.com/library.php
There a non-official version of Ferduino code for 320 x 240 HERE, but I won't give support for it.
Post Number:#3 Post Mon May 23, 2016 10:43 am
Hi Fernando, what do you think aboit that:
O envio gratuito de New 3.2 "240x400 TFT LCD Módulo de Display Touch Panel Adaptador PCB ILI9327 Arduino para 3.2 polegada 240*400
http://s.aliexpress.com/7fU3UbMV
(from AliExpress Android)
Thanks.
Post Number:#4 Post Mon May 23, 2016 10:51 am
This is not compatible. Check this: https://www.itead.cc/display/tft-lcm/itdb02-3-2wd.html
Post Number:#5 Post Mon May 23, 2016 11:55 am
I bought it right now.
So... I give you some peace... for now... uahahua
