Forum Software Ferduino code Problem with heater
Problem with heater  [SOLVED]
Post Number:#1 Post Wed Apr 29, 2015 6:09 pm
hi
I'm new in the forum sorry for my english but I use google translator ...
I have a problem with the heater, when the temperature drops to below the set minimum level the relay becomes on but just reaches the minimum level becomes off without reaching the reference temperature.
in this way the relays are constantly changing state.
to remedy this problem is corrected to change the code so ??
if (offTempC > 0)
    if ((tempC > (setTempC + offTempC)))            // Liga o chiller
      while(tempC)
      bitWrite(status_parametros,0,1);
      digitalWrite(chillerPin, HIGH);
    if ((tempC < (setTempC - offTempC)))             // Liga o aquecedor
      while(tempC)
      bitWrite(status_parametros,1,1);
      digitalWrite(aquecedorPin, HIGH);
thank you very much for your attention
danilo
Post Number:#2 Post Thu Apr 30, 2015 12:01 pm
It's completely wrong check this page: http://www.arduino.cc/en/Reference/While
You need work with this lines:
Post Number:#3 Post Thu Apr 30, 2015 5:46 pm
hi
I understand that there is a compilation error of the while statement.
is correct to use the while istruction or using this type of instruction there is a risk that the controller goes into an infinite loop?
I thought to correct the statement with these two.
while((tempC < setTempC ))
while((tempC > setTempC ))
Post Number:#4 Post Thu Apr 30, 2015 9:48 pm
What are the values possible to tempC and setTempC?
Replace this values and tell me if will make what you want.
Post Number:#5 Post Fri May 01, 2015 11:30 am
hi Fernando
I now set so:
setTempC = 25.5
offTempC = 0.7
I wish that when the temperature of the aquarium (tempC) descends for example at 24.7 ° C the heater turning on and remain on until 25 ° .5 and not turn OFF as it happens now at 24.8 ° C.
my only fear is that during the entire period in which the heater is on the controller does not perform most other commands
Post Number:#6 Post Fri May 01, 2015 1:11 pm
You can't use a "while" on this case.
Try another method.
Post Number:#7 Post Sat May 02, 2015 11:22 am
hi fernando
let's see if this method can go :-s :-s :-s .
I do not know anything about programming but I'm trying to apply myself to understand how to make and I hope also with your help :D :D :D :D
I defined three boolean variable is then thought to modify the code like this:
 if (tempC < (setTempC + offTempC + alarmTempC) && tempC > (setTempC - offTempC - alarmTempC))
    bitWrite(status_parametros,2,0);
  if (alarmTempC > 0)                        // Aciona alarme
    if ((tempC >= (setTempC + offTempC + alarmTempC)) || (tempC <= (setTempC - offTempC - alarmTempC)))
      bitWrite(status_parametros,2,1);
  if ((tempC < (setTempC + offTempC)) && (tempC > (setTempC - offTempC)))          // Desliga aquecedor e chiller
    bitWrite(status_parametros,0,0);
    bitWrite(status_parametros,1,0);
    digitalWrite(aquecedorPin, LOW);
    digitalWrite(chillerPin, LOW);
  if (offTempC > 0)
    if ((tempC > (setTempC + offTempC)))            //   ocorre entre ligar o chiller
            temperatura_max_set = true;
            temperatura_ok = false;
            temperatura_min_set = false;
    if ((tempC < (setTempC - offTempC)))             // ocorre entre ligar o aquecedor
                temperatura_min_set = true;
                temperatura_max_set = false;
    if (temperatura_max_set == true)            // ocorre entre desligar o chiller
         if ((tempC <= (setTempC)))
                 temperatura_ok = true;
    if (temperatura_min_set == true)
        if ((tempC >= (setTempC)))             // ocorre entre desligar o aquecedor
    if (temperatura_max_set == true)            // Liga o chiller
    if (temperatura_min_set ==true)             // Liga o aquecedor
 if (temperatura_ok==true)                    //desliga o chiller e aquecedor
  if ((tempC > 50) || (tempC <10))
  if ((bitRead(status_parametros, 0) == true) &&  (bitRead(status_parametros, 1) == true)) // Evita aquecedor e chiller ligados ao mesmo tempo.
  int tempval = int(tempH * 10);
  fanSpeed = map(tempval, (HtempMin * 10), (HtempMax * 10), 0, 255);       // Controle de velocidade das ventoinhas do dissipador
  if (fanSpeed < 0)
    fanSpeed = 0;
  if (fanSpeed > 255)
    fanSpeed = 255;
  analogWrite(fanPin, fanSpeed);
  if(tempH < HtempMin) // Desativa os coolers se a temperatura estive abaixo da mínima definida.
    digitalWrite(desativarFanPin, LOW);
    digitalWrite(desativarFanPin, HIGH);
