Forum Software Ferduino code Graphic temperature discontinuous
Post Number:#1 Post Wed Nov 05, 2014 6:06 pm
Topics: 22
Topics: 22
hi
I'm using the code ferduino (no network card no website) in the temperature graph I have a broken line with the purple on the bottom punished
what do I do?
here's the picture
Last edited by Fernando Garcia on Wed Nov 05, 2014 6:10 pm, edited 1 time in total.
Reason: Image fixed.
Post Number:#2 Post Wed Nov 05, 2014 6:14 pm
Can you show me the values stored on file "LOGTDIA.TXT" at SD card?
Post Number:#3 Post Thu Nov 06, 2014 5:33 pm
Topics: 22
Topics: 22
Post Number:#4 Post Thu Nov 06, 2014 6:15 pm
You have some problem with probes.
Look this values:
25.50
12.79
25.50
25.50
12.79
25.50
25.50
25.50
25.50
25.50
25.50
12.79
12.79
25.50
25.50
25.50
Your .TXT have this "?" after each value?
Post Number:#5 Post Thu Nov 06, 2014 6:49 pm
Topics: 22
Topics: 22
not in the txt there are no "?"
I have 2 temperature probes
1 for water
1 sink
both measures are equal
what do I do?
the wires of the probes can be as long?
Post Number:#6 Post Thu Nov 06, 2014 7:20 pm
Maybe, I'm using a cable with 300 cm and I haven't any problem.
Post Number:#7 Post Fri Nov 07, 2014 9:34 am
Topics: 22
Topics: 22
resistance should be close to Arduino or makes no difference?
but I have to connect 2 wires to the temperature sensor? as shown in the diagram?
data and + gnd only?
Post Number:#8 Post Fri Nov 07, 2014 10:21 am
No matter.
You can use the normal mode (gnd + data + vcc) too.
Check if you have problem of oxidation on sensor.
