// UTFT_Demo_480x272 (C)2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 480x272 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield : <display model>,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield : <display model>,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ITDB43,38,39,40,41);
randomSeed(analogRead(0));
// Setup the LCD
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
int buf[478];
int x, x2;
int y, y2;
int r;
// Clear the screen and draw the frame
myGLCD.clrScr();
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 479, 13);
myGLCD.setColor(64, 64, 64);
myGLCD.fillRect(0, 258, 479, 271);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
myGLCD.setBackColor(64, 64, 64);
myGLCD.setColor(255,255,0);
myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 259);
myGLCD.setColor(0, 0, 255);
myGLCD.drawRect(0, 14, 479, 257);
// Draw crosshairs
myGLCD.setBackColor(0, 0, 0);
myGLCD.drawLine(239, 15, 239, 256);
myGLCD.drawLine(1, 135, 478, 135);
for (int i=9; i<470; i+=10)
myGLCD.drawLine(i, 133, i, 138);
for (int i=15; i<256; i+=10)
myGLCD.drawLine(237, i, 241, i);
// Draw sin-, cos- and tan-lines
myGLCD.setColor(0,255,255);
myGLCD.print("Sin", 5, 15);
for (int i=1; i<478; i++)
myGLCD.drawPixel(i,135+(sin(((i*1.13)*3.14)/180)*95));
myGLCD.setColor(255,0,0);
myGLCD.print("Cos", 5, 27);
myGLCD.drawPixel(i,135+(cos(((i*1.13)*3.14)/180)*95));
myGLCD.print("Tan", 5, 39);
myGLCD.drawPixel(i,135+(tan(((i*1.13)*3.14)/180)));
delay(2000);
myGLCD.setColor(0,0,0);
myGLCD.fillRect(1,15,478,256);
// Draw a moving sinewave
x=1;
for (int i=1; i<(478*20); i++)
x++;
if (x==479)
x=1;
if (i>479)
if ((x==239)||(buf[x-1]==135))
myGLCD.setColor(0,0,255);
myGLCD.drawPixel(x,buf[x-1]);
y=135+(sin(((i*1.65)*3.14)/180)*(90-(i / 100)));
myGLCD.drawPixel(x,y);
buf[x-1]=y;
delay(2000);
// Draw some filled rectangles
for (int i=1; i<6; i++)
switch (i)
case 1:
myGLCD.setColor(255,0,255);
break;
case 2:
break;
case 3:
myGLCD.setColor(0,255,0);
break;
case 4:
break;
case 5:
break;
myGLCD.fillRect(150+(i*20), 46+(i*20), 210+(i*20), 106+(i*20));
delay(2000);
// Draw some filled, rounded rectangles
switch (i)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
myGLCD.fillRoundRect(330-(i*20), 46+(i*20), 270-(i*20), 106+(i*20));
delay(2000);
// Draw some filled circles
switch (i)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
myGLCD.fillCircle(180+(i*20),75+(i*20), 30);
delay(2000);
// Draw some lines in a pattern
myGLCD.setColor (255,0,0);
for (int i=15; i<256; i+=5)
myGLCD.drawLine(1, i, (i*1.88)-10, 256);
for (int i=256; i>15; i-=5)
myGLCD.drawLine(478, i, (i*1.88)-11, 15);
myGLCD.setColor (0,255,255);
myGLCD.drawLine(1, i, 491-(i*1.88), 15);
myGLCD.drawLine(478, i, 490-(i*1.88), 256);
delay(2000);
// Draw some random circles
for (int i=0; i<150; i++)
myGLCD.setColor(random(255), random(255), random(255));
x=32+random(416);
y=45+random(178);
r=random(30);
myGLCD.drawCircle(x, y, r);
delay(2000);
// Draw some random rectangles
x=2+random(476);
y=16+random(239);
x2=2+random(476);
y2=16+random(239);
myGLCD.drawRect(x, y, x2, y2);
delay(2000);
// Draw some random rounded rectangles
x=2+random(476);
y=16+random(239);
x2=2+random(476);
y2=16+random(239);
myGLCD.drawRoundRect(x, y, x2, y2);
delay(2000);
x=2+random(476);
y=16+random(239);
x2=2+random(476);
y2=16+random(239);
myGLCD.drawLine(x, y, x2, y2);
delay(2000);
for (int i=0; i<10000; i++)
myGLCD.drawPixel(2+random(476), 16+random(239));
delay(2000);
myGLCD.fillScr(0, 0, 255);
myGLCD.fillRoundRect(160, 70, 319, 169);
myGLCD.print("That's it!", CENTER, 93);
myGLCD.print("Restarting in a", CENTER, 119);
myGLCD.print("few seconds...", CENTER, 132);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 255);
myGLCD.print("Runtime: (msecs)", CENTER, 243);
myGLCD.printNumI(millis(), CENTER, 258);
delay (1000);
// UTouch_Calibration (C)2012 Henning Karlsen
// This program can be used to calibrate the touchscreen
// of the display modules.
// This program requires the UTFT library and a touch
// screen module that is compatible with UTFT.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
// Instructions will be given on the display.
#include <UTFT.h>
#include <UTouch.h>
// Define the orientation of the touch screen. Further
// information can be found in the instructions.
#define TOUCH_ORIENTATION PORTRAIT
// Uncomment the next two lines for the Arduino 2009/UNO
//UTFT myGLCD(ITDB24D,19,18,17,16); // Remember to change the model parameter to suit your display module!
//UTouch myTouch(15,10,14,9,8);
// Uncomment the next two lines for the Arduino Mega
UTFT myGLCD(ITDB43,38,39,40,41); // Remember to change the model parameter to suit your display module!
UTouch myTouch(6,5,4,3,2);
uint32_t cx, cy;
uint32_t rx[10], ry[10];
uint32_t clx, crx, cty, cby;
float px, py;
int dispx, dispy, text_y_center;
uint32_t calx, caly, cals;
char buf[13];
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch(TOUCH_ORIENTATION);
myTouch.setPrecision(PREC_LOW);
dispx=myGLCD.getDisplayXSize();
dispy=myGLCD.getDisplayYSize();
text_y_center=(dispy/2)-6;
void drawCrossHair(int x, int y)
myGLCD.drawRect(x-10, y-10, x+10, y+10);
myGLCD.drawLine(x-5, y, x+5, y);
myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
int iter = 2000;
int cnt = 0;
uint32_t tx=0;
uint32_t ty=0;
boolean OK = false;
while (OK == false)
myGLCD.print("* PRESS *", CENTER, text_y_center);
while (myTouch.dataAvailable() == false) {}
myGLCD.print("* HOLD! *", CENTER, text_y_center);
while ((myTouch.dataAvailable() == true) && (cnt<iter))
myTouch.read();
tx += myTouch.TP_X;
ty += myTouch.TP_Y;
cnt++;
if (cnt>=iter)
OK = true;
tx = 0;
ty = 0;
cnt = 0;
cx = tx / iter;
cy = ty / iter;
void calibrate(int x, int y, int i)
drawCrossHair(x,y);
readCoordinates();
myGLCD.print("* RELEASE *", CENTER, text_y_center);
myGLCD.setColor(80, 80, 80);
drawCrossHair(x,y);
rx[i]=cx;
ry[i]=cy;
while (myTouch.dataAvailable() == true)
myTouch.read();
void waitForTouch()
myTouch.read();
myTouch.read();
void toHex(uint32_t num)
buf[0] = '0';
buf[1] = 'x';
buf[10] = 'U';
buf[11] = 'L';
buf[12] = 0;
for (int zz=9; zz>1; zz--)
if ((num & 0xF) > 9)
buf[zz] = (num & 0xF) + 55;
buf[zz] = (num & 0xF) + 48;
num=num>>4;
void startup()
myGLCD.fillRect(0, 0, dispx-1, 13);
myGLCD.drawLine(0, 14, dispx-1, 14);
myGLCD.print("UTouch Calibration", CENTER, 1);
if (dispx==220)
myGLCD.print("Use a stylus or something", LEFT, 30);
myGLCD.print("similar to touch as close", LEFT, 42);
myGLCD.print("to the center of the", LEFT, 54);
myGLCD.print("highlighted crosshair as", LEFT, 66);
myGLCD.print("possible. Keep as still as", LEFT, 78);
myGLCD.print("possible and keep holding", LEFT, 90);
myGLCD.print("until the highlight is", LEFT, 102);
myGLCD.print("removed. Repeat for all", LEFT, 114);
myGLCD.print("crosshairs in sequence.", LEFT, 126);
myGLCD.print("Touch screen to continue", CENTER, 162);
myGLCD.print("INSTRUCTIONS", CENTER, 30);
myGLCD.print("Use a stylus or something similar to", LEFT, 50);
myGLCD.print("touch as close to the center of the", LEFT, 62);
myGLCD.print("highlighted crosshair as possible. Keep", LEFT, 74);
myGLCD.print("as still as possible and keep holding", LEFT, 86);
myGLCD.print("until the highlight is removed. Repeat", LEFT, 98);
myGLCD.print("for all crosshairs in sequence.", LEFT, 110);
myGLCD.print("Further instructions will be displayed", LEFT, 134);
myGLCD.print("when the calibration is complete.", LEFT, 146);
myGLCD.print("Do NOT use your finger as a calibration", LEFT, 170);
myGLCD.print("stylus or the result WILL BE imprecise.", LEFT, 182);
myGLCD.print("Touch screen to continue", CENTER, 226);
waitForTouch();
myGLCD.clrScr();
void done()
myGLCD.clrScr();
if (dispx==220)
myGLCD.print("To use the new calibration", LEFT, 30);
myGLCD.print("settings you must edit the", LEFT, 42);
myGLCD.setColor(160, 160, 255);
myGLCD.print("UTouchCD.h", LEFT, 54);
myGLCD.print("file and change", 88, 54);
myGLCD.print("the following values. The", LEFT, 66);
myGLCD.print("values are located right", LEFT, 78);
myGLCD.print("below the opening comment.", LEFT, 90);
myGLCD.print("CAL_X", LEFT, 110);
myGLCD.print("CAL_Y", LEFT, 122);
myGLCD.print("CAL_S", LEFT, 134);
toHex(calx);
myGLCD.print(buf, 75, 110);
toHex(caly);
myGLCD.print(buf, 75, 122);
toHex(cals);
myGLCD.print(buf, 75, 134);
myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
myGLCD.print("To use the new calibration", LEFT, 50);
myGLCD.print("settings you must edit the", LEFT, 62);
myGLCD.print("UTouchCD.h", LEFT, 74);
myGLCD.print("file and change", 88, 74);
myGLCD.print("the following values.", LEFT, 86);
myGLCD.print("The values are located right", LEFT, 98);
myGLCD.print("below the opening comment in", LEFT, 110);
myGLCD.print("the file.", LEFT, 122);
myGLCD.print("CAL_X", LEFT, 150);
myGLCD.print("CAL_Y", LEFT, 162);
myGLCD.print("CAL_S", LEFT, 174);
toHex(calx);
myGLCD.print(buf, 75, 150);
toHex(caly);
myGLCD.print(buf, 75, 162);
toHex(cals);
myGLCD.print(buf, 75, 174);
startup();
drawCrossHair(dispx-11, 10);
drawCrossHair(dispx/2, 10);
drawCrossHair(10, 10);
drawCrossHair(dispx-11, dispy/2);
drawCrossHair(10, dispy/2);
drawCrossHair(dispx-11, dispy-11);
drawCrossHair(dispx/2, dispy-11);
drawCrossHair(10, dispy-11);
myGLCD.print("***********", CENTER, text_y_center-12);
myGLCD.print("***********", CENTER, text_y_center+12);
calibrate(10, 10, 0);
calibrate(10, dispy/2, 1);
calibrate(10, dispy-11, 2);
calibrate(dispx/2, 10, 3);
calibrate(dispx/2, dispy-11, 4);
calibrate(dispx-11, 10, 5);
calibrate(dispx-11, dispy/2, 6);
calibrate(dispx-11, dispy-11, 7);
if (TOUCH_ORIENTATION == LANDSCAPE)
cals=(long(dispx-1)<<12)+(dispy-1);
cals=(long(dispy-1)<<12)+(dispx-1);
if (TOUCH_ORIENTATION == PORTRAIT)
px = abs(((float(rx[2]+rx[4]+rx[7])/3)-(float(rx[0]+rx[3]+rx[5])/3))/(dispy-20)); // PORTRAIT
px = abs(((float(rx[5]+rx[6]+rx[7])/3)-(float(rx[0]+rx[1]+rx[2])/3))/(dispy-20)); // LANDSCAPE
clx = (((rx[0]+rx[3]+rx[5])/3)); // PORTRAIT
crx = (((rx[2]+rx[4]+rx[7])/3)); // PORTRAIT
clx = (((rx[0]+rx[1]+rx[2])/3)); // LANDSCAPE
crx = (((rx[5]+rx[6]+rx[7])/3)); // LANDSCAPE
if (clx<crx)
clx = clx - (px*10);
crx = crx + (px*10);
clx = clx + (px*10);
crx = crx - (px*10);
py = abs(((float(ry[5]+ry[6]+ry[7])/3)-(float(ry[0]+ry[1]+ry[2])/3))/(dispx-20)); // PORTRAIT
py = abs(((float(ry[0]+ry[3]+ry[5])/3)-(float(ry[2]+ry[4]+ry[7])/3))/(dispx-20)); // LANDSCAPE
cty = (((ry[5]+ry[6]+ry[7])/3)); // PORTRAIT
cby = (((ry[0]+ry[1]+ry[2])/3)); // PORTRAIT
cty = (((ry[0]+ry[3]+ry[5])/3)); // LANDSCAPE
cby = (((ry[2]+ry[4]+ry[7])/3)); // LANDSCAPE
if (cty<cby)
cty = cty - (py*10);
cby = cby + (py*10);
cty = cty + (py*10);
cby = cby - (py*10);
calx = (long(clx)<<14) + long(crx);
caly = (long(cty)<<14) + long(cby);
cals = cals + (1L<<31);
done();
while(true) {}
Users viewing this topic: No registered users and 26 guests
