Forum Software Ferduino code Problem loading IDE with multiplexer
Problem loading IDE with multiplexer  [SOLVED]
Post Number:#1 Post Tue Jan 29, 2019 10:05 pm
Boa note,
I recently purchased the Atlas Scientific multiplexer along with two EZO pH circuits and two Electrically Isolated EZO Carrier Boards. I attach the connection scheme that I followed, as I also use the ESP8266 module instead of using pins 16 and 17 I used the A6 and A7 that I have free.
If I test with the test code and under the baud rate, 9600 works perfectly and I receive correct readings from the two probes (if I leave it in 34800, it shows erroneous characters).foto1:
https://ibb.co/5vtvHZc
The problem occurs when loading the code of Ferduino, when enabling the lines #define STAMPS_EZO,STAMP FOR TANK PH and STAMP FOR CALCIUM REACTOR, the screen remains in black and with blank screenshots.
I do not understand what the problem is.
Can you help me?
Tks and regards
Post Number:#2 Post Tue Jan 29, 2019 10:43 pm
