Forum Members section DIY Ferduino controller PCF8575 Removable
PCF8575 Removable  [SOLVED]
Post Number:#1 Post Mon Sep 10, 2018 9:24 am
Indonesia
Hello fernando how are you.
I want to ask if maybe pcf8575 is made removable, because I want the controller and riley separate, so just use the USB cable from the controller to the relay. if needed I just need to connect, do not make an error controller, if it is not used, stay unplugged.
Post Number:#2 Post Mon Sep 10, 2018 9:40 am
You can't because the controller will say searching for PCF module and will give a white screen if not find.
You can leave the PCF connected to controller and bring a cable with needed amount of wires to relay board as I did with: https://ferduino.com/product/solid-stat ... -channels/
-------------------------------- Last edited Mon Sep 10, 2018 9:44 am --------------------------------
BTW: I'm fine, thanks!
I hope you are are fine too. :D
Post Number:#3 Post Mon Sep 10, 2018 9:54 am
Indonesia
OK, thank you, for your very quick answer. :-bd :-bd
now I use RJ 45, but it's still not simple. because I want to make the main controller as small as possible.
I think it can removable.. :D
thanks
best regards
