Forum Members section Show your controller JZM Ferduino build
JZM Ferduino build
Post Number:#1 Post Thu Feb 15, 2018 10:30 am
Finally I can show my progress, I have decided to make modules instead of a single PCB and so far I have:
Module 1: Temperature probes, level probes and dosing pumps
Module 2: Clock and Relays-2
Module 3: Alarm and output for surface fans and led fans
Module 4: Dosing pumps module
Finally I show a picture of the assembly that I have running at this time, the connection is by WiFi
What I need are suggestions for finding boxes for housing the entire assembly, the dosing pumps and the relay module and electrical outlets.
Greetings and apologies for my poor English
Post Number:#2 Post Thu Feb 15, 2018 8:22 pm
Great job!
The better solutions are 3D printed cases. You can draw the boxes and ask to someone (Fraidias :D) print it for.
You can try 3D Hub too.
Post Number:#3 Post Thu Aug 23, 2018 2:35 pm
Finally instead of modules I have designed a plate that fits my needs, it is "copied" from Ferduino Mega but with certain limitations and some changes like the possibility of choosing if I want to cool the water by means of surface fans or a cooler. As for the dosing machines I added a led on each PCB to see when they are in operation and to house them I used a box to order cables.
The box to house the shield and other components is commercial and being quite large I have left inside the relays that control the heater and the cooler and at the time I will put Atlas-Scientific modules.
But at the moment I can start.
The next step is to look for a box to install the relay module-2.
It has cost me a lot but I'm happy.
I wish I could have bought the Ferduino Mega 2560, I would have saved many hours of work !!
Post Number:#4 Post Thu Aug 23, 2018 3:17 pm
Great job friend!
Thanks for share your build here. Go on!
I would like have a Ferduino M. to sell for you but I have sure that you had learned a lot building this controller. :D
