Forum Members section Show your controller Real amateur Build.
Real amateur Build.
Post Number:#61 Post Sun Jul 02, 2017 10:32 am
Images: 13
Greece
Post Number:#62 Post Sun Jul 02, 2017 10:57 am
Using carrier board the BNC and expander are useless.
If you will use an EC module the isolator will be needed for it.
For pH and ORP only this module should be enough for both.
Post Number:#63 Post Tue Jul 04, 2017 6:15 am
Images: 13
Greece
I have a Real noob question about buzzer diagram. I connect the buzzer's +pin to middle trimmer pin. Where i connect the left and right trimmer pin?. How can i find the positive pin? I have this trimmer.
Best Regards
Post Number:#64 Post Tue Jul 04, 2017 10:22 am
I did some changes on circuit. It should be better.
Post Number:#65 Post Wed Jul 05, 2017 5:18 pm
Images: 13
Greece
Post Number:#66 Post Sat Jul 08, 2017 10:56 am
Images: 13
Greece
Just a quick question. I want to add a simple led light, like in alarm, to SSR functions like chiller, heater, etc. How can i do that?
Best Regards.
Post Number:#67 Post Sat Jul 08, 2017 11:31 am
Connect the digital pin to an ULN in parallel with SSR.
The resistor can be 1K.
Post Number:#68 Post Sat Jul 08, 2017 12:45 pm
Images: 13
Greece
Image: http://jason-webb.info/wp-content/uploads/2010/12/schematic.png
To be more specific. I want, when chiller is on, want a led turns on, when chiller is off, the led turns off. The same i want with heater and so on....
So, if i understand well, i connect led1 to pin 43 for chiller, and only to ground?
I also have a problem with the ssr. I'm trying to test chiller function. When the chiller function turns on the fan i connected doesn't turn on. when i disconnect the + cable and connect it again it turns on. When the chiller function turns off the fan doesn't turn off. When i disconnect the + cable and connect it again it turns off. What is going on?
Post Number:#69 Post Sat Jul 08, 2017 1:55 pm
Try understand the schematic above before ask, I didn't told to connect any LED directly to digital pin.
1 - Test the circuit first with a blink;
2 - Show me the circuit;
3 - Which type of fan are you using?.
Post Number:#70 Post Sat Jul 08, 2017 3:39 pm
Images: 13
Greece
I didn't say that. I asked if i have to connect e.g. ULN2003AN I1 to chiller pin and ULN2003AN GND 8 only to gnd cause Arduino's D1-D7 and D8-D16 are used for other purposes.
Post Number:#71 Post Sat Jul 08, 2017 4:46 pm
Check your question again.
Obviously you can't use D1 to D7, it's only an example I got from Google.
You should try understand the logic of this circuit, I can't give all done for you.
Moreover you are wasting money using a SSR to control this fan. It can be like this:
Using 330 Ohms the LED should work with 3 V and 27.3 mA.
Post Number:#72 Post Sat Jul 08, 2017 5:11 pm
Images: 13
Greece
Image: https://farm5.staticflickr.com/4213/34992018753_9acde60683_o.png
I' m planning to use 8 fans for cooling. In that case i think i will need at least 3 ULN and already have the SSR for the heater. So i thought is simpler to connect the fans to SSR.
Post Number:#73 Post Sat Jul 08, 2017 5:29 pm
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=110
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=378
In the first image you can see F1, F2.... F7. It mean a fan to each pin, total 7 fans per ULN.
Post Number:#74 Post Sun Jul 09, 2017 2:04 pm
Images: 13
Greece
Yes i know that, but when i tried to connect led fans i saw that one ULN can't hold 4 fans, so i had to split them in two ULNs.
Post Number:#75 Post Sun Jul 09, 2017 2:33 pm
You did something wrong.
According to datasheet the total current on pin 8 can be 2.5A more than your SSR (2A).
So you can use 2500 / 7 = 357 mA per pin.
Are you using 5 V from Arduino to supply this relay board?
I think this SSR can't work with DC since it has a resistive fuse. Try with AC load.
Description:
5V Omron solid state relays 240V 2A, output with resistive fuse 240V 2A
Post Number:#76 Post Wed Jul 19, 2017 9:03 am
Images: 13
Greece
Description:
Yes the SSR can't work with DC. I connected to 220V AC and worked.
A quick question: I don't have a PCF8575. Where can i connect solenoide1Pin and sump lights?
Best Regards.
Post Number:#77 Post Wed Jul 19, 2017 9:34 am
Use free pins in your system as pin 7.
I have explained it many times here search a bit.
http://www.ferduino.com/forum/viewtopic ... swap#p3139
Post Number:#78 Post Wed Jul 19, 2017 9:47 pm
Images: 13
Greece
I have a question regarding sensor3. I connected it to A2 arduino pin. When the chiller is on the ATO function stop working. When chiller is off the ATO function works just right. Is it normal? If yes, how can i bypass it?
Best Regards.
Post Number:#79 Post Thu Jul 20, 2017 8:21 am
Indonesia
Best Regards.
Little answer, that's normal, because it interacts with the chiller.
best regards
Post Number:#80 Post Thu Jul 20, 2017 8:42 am
It's a feature to prevent fill the tank with freshwater when there a leak on chiller.
In "parametros" tab remove this condition:
&& (bitRead(status_parametros, 0) == false)
if ((myAnalogRead(sensor3) > 400) && (myAnalogRead(sensor2) > 400) && (bitRead(tpa_status, 1) == false) && (bitRead(status_parametros, 0) == false) && (bitRead(tpa_status, 2) == false))
