Forum Members section Show your controller Real amateur Build.
Real amateur Build.
Post Number:#21 Post Wed Mar 22, 2017 4:45 pm
Can be but Solid State Relay is better than mechanical relay.
The problem with SSR is max. current (2 A).
Post Number:#22 Post Sun Mar 26, 2017 1:39 pm
Images: 13
Greece
Today i started assembly arduino mega whith screw shield and ethernet shield:
I connected the temperature sensors and tested them. I decided to use a pcb board for the wirring. So far so good:
Last edited by Fernando Garcia on Sun Mar 26, 2017 2:40 pm, edited 3 times in total.
Reason: Please use the tags [img=left][/img] to post images. Removed duplicated images.
Post Number:#23 Post Sun Mar 26, 2017 4:35 pm
Images: 13
Greece
Post Number:#24 Post Sun Mar 26, 2017 5:03 pm
The more cheap and easy solution is a LED strip connected to an ULN 2003.
-------------------------------- Last edited Sun Mar 26, 2017 5:08 pm --------------------------------
The circuit is like this:
Post Number:#25 Post Wed Apr 12, 2017 5:59 am
Images: 13
Greece
In this post you say that V. control is a trimmer and LED-OUTPUT is a connector molex. Can you give me an image of what I will need? I quess that the jumper is a standard computer jumper.
Post Number:#26 Post Wed Apr 12, 2017 8:29 am
Molex 2 pins:
Buzzer:
Trimmer:
Jumper:
Transistor:
LED 5mm:
Post Number:#27 Post Tue Apr 25, 2017 6:23 pm
Images: 13
Greece
Hi
Today i received my lcd from emartee, but i have problems. The touch screen does not respond at all when i use the URtouch library, button test and calibration. I used the ITDB02_Touch library and responds but the coordinates are wrong. I tried several times to calibrate the screen, but no luck. Any ideas?
Best Regards.
EDIT: I replaced URtouch with Utouch and now the screen is responding. The problem is that i can't calibrate it properly. I tried many times with no luck.
Post Number:#28 Post Wed Apr 26, 2017 3:10 am
Images: 13
Greece
I managed to calibrate the screen using a newer version of URtouch and setting the orientation to landscape. Now when ferduino starts it stacks in menu 1 screen and I can't use the menus. I'm using the ITDB02 shield and the ethernet shield. Another thing I noticed, is when I use only a 12v 5A power supply, without the usb cable, the LCD screen starts blinking black and white.
Post Number:#29 Post Wed Apr 26, 2017 8:22 am
Have you checked this part of your code?
Mainly:
//#define USE_TFT_SHIELD
Post Number:#30 Post Sun Apr 30, 2017 10:04 am
Images: 13
Greece
i made the changes you suggested, and it worked like a charm!!! I had some problems using the ethernet shield, like random ASCII characters in the bottom of the screen, so i decided to remove it for now. I connected the temp sensors and all seems to go well. Do i need to waterproof them?
The next thing i' m planning to connect is the heater. It uses pin 42 right?
Post Number:#31 Post Sun Apr 30, 2017 12:01 pm
It seems related with RTC not working fine. Maybe related with low voltage on 5V circuit. Which power supply (voltage / current) are you using?
Yes.
Yes, as you can see here.
Post Number:#32 Post Mon May 01, 2017 3:56 am
Images: 13
Greece
I' m using a 12V 5A power supply. Is this power enough to connect the relay board directly to arduino or i will need another one?
Yes.
Is just enough to coat them with silicone?
Post Number:#33 Post Mon May 01, 2017 8:26 am
You can't connect the relay board directly to Arduino. The 5V circuit on Arduino can work only with 800 mA.
You should use a step down connected to this 12V power supply as I told before.
Yes.
-------------------------------- Last edited Mon May 01, 2017 8:52 am --------------------------------
Another thing, when using 12V to power the Aduino is needed a fan to cooling the regulator.
You can power the Arduino directly on 5V pin with 5V from step down so, don't needs add a fan.
Post Number:#34 Post Mon May 01, 2017 1:10 pm
Images: 13
Greece
I' m connecting the ssr with the step down regulator adjusted to 5v, but gives no power to ssr. when i connect the ssr directly to arduino, it works fine. The power supply is 12V 1A.
Post Number:#35 Post Mon May 01, 2017 1:31 pm
Join GND from power supply with Arduino GND.
Post Number:#36 Post Sun May 21, 2017 1:33 pm
Can you post the setup and touch coordinates that are you using for your TFT from Emartee? Some peoples have problem with this TFT.
Post Number:#37 Post Sun Jun 04, 2017 2:17 pm
Images: 13
Greece
Hi, sorry for the late answer. The coordinates that i used for URTouch library are:
#define CAL_X 0x0045CFBBUL
#define CAL_Y 0x039FC143UL
#define CAL_S 0x8018F0EFUL
I think, i changed the orientation from PORTRAIT to LANDSCAPE in calibration. The driver i used is the HX8352A.
I almost finished the led setup (i' ll post pictures soon) and i' m searching for the water top off. Now i' m using a set up providing by this thread and i' m wondering if there's a way to modify it for ferduino. I want to keep it simple. I want a pump start to fill the sub when the water level is below the floaters.
Best Regards.
Last edited by Fernando Garcia on Sun Jun 04, 2017 5:36 pm, edited 1 time in total.
Reason: Please use the tags [code][/code] to post a code.
Post Number:#38 Post Sun Jun 04, 2017 5:35 pm
Thanks for your feedback.
Which TFT shield are you using?
Regarding ATO, connect the pump to "solenoide1Pin" and float switch to "sensor3". There many topics here about it.
Post Number:#39 Post Mon Jun 05, 2017 5:06 am
Images: 13
Greece
Post Number:#40 Post Mon Jun 05, 2017 11:24 am
Thank you.
