Forum Software Ferduino code Arduino mega pins
Arduino mega pins  [SOLVED]
Post Number:#1 Post Sun Feb 26, 2017 3:05 pm
Greece
hello my friend any help for the pins of leds timers temp sensors?
i need other pcbs?
sorry for my english isnt very good
Post Number:#2 Post Sun Feb 26, 2017 3:08 pm
As I told before: https://github.com/FernandoGarcia/Ferdu ... a.ino#L207
A prototype shield or screw shield is needed to connect all devices.
Post Number:#3 Post Sun Feb 26, 2017 4:02 pm
Greece
from arduino mega board
the pins for led
const byte ledPinUV = 8;         // Pino que liga os leds violeta
const byte ledPinBlue = 9;       // Pino que liga os leds azuis
const byte ledPinWhite = 10;     // Pino que liga os leds brancos
const byte ledPinRoyBlue = 11;   // Pino que liga os leds "royal blue"
const byte ledPinRed = 12;
and for timer1 2 3 etc?
can i work timers without PCF8575?
Last edited by Fernando Garcia on Sun Feb 26, 2017 4:08 pm, edited 2 times in total.
Reason: Pease use the tag [code][/code] to post codes.
Post Number:#4 Post Sun Feb 26, 2017 4:13 pm
Yes, only swap the pin numbers with a free pin in your system.
If you won't use wavemaker you can make like this:
const byte temporizador1 = 80;
const byte temporizador2 = 81;
const byte wavemaker1 = 45;
const byte wavemaker2 = 46;
Change to:
const byte temporizador1 = 45;
const byte temporizador2 = 46;
const byte wavemaker1 = 80;
const byte wavemaker2 = 81;
In your case the pin 7 is free too so you can make like this:
const byte temporizador3 = 7;
Post Number:#5 Post Sun Feb 26, 2017 4:58 pm
Greece
thank you fernando i try it.....
Post Number:#6 Post Tue Feb 28, 2017 5:55 pm
Greece
hi fernando again...
i try it but i can find nothing ...
now the code running on 5 inch tft and i have find the pins of leds and wavemakers and can find the 5 timers. any help? what change can i take to work....
i dont use the dosing pump skimmer ozone
Post Number:#7 Post Tue Feb 28, 2017 6:09 pm
What's your problem?
The posts above are not clear?
Post Number:#8 Post Tue Feb 28, 2017 7:06 pm
Greece
in lines
const byte temporizador1 = 5;       // P5       // Pin that turns on the timer 1.
const byte temporizador2 = 6;       // P6       // Pin that turns on the timer 2.
const byte temporizador3 = 7;       // P7       // Pin that turns on the timer 3.
const byte temporizador4 = 8;       // P8       // Pin that turns on the timer 4.
const byte temporizador5 = 9;       // P9       // Pin that turns on the timer 5.
i change the pins
const byte temporizador1 = A5;       // P5       // Pin that turns on the timer 1.
const byte temporizador2 = A6;       // P6       // Pin that turns on the timer 2.
const byte temporizador3 = A7;       // P7       // Pin that turns on the timer 3.
const byte temporizador4 = A8;       // P8       // Pin that turns on the timer 4.
const byte temporizador5 = A9;       // P9       // Pin that turns on the timer 5.
are that correct? and the old pins a5 a6 a7 a8 a9 i change with these 5 6 7 8 9 ?
Last edited by Fernando Garcia on Tue Feb 28, 2017 7:12 pm, edited 1 time in total.
Post Number:#9 Post Tue Feb 28, 2017 7:17 pm
Which part of this text you don't understand?
///************************************** PCF8575 ****************************************************
// Do not change this part if you have not a PCF8575 installed.
You should change this part according to what I told above.
const byte temporizador1 = 80;           // Pino que liga o timer 1.
const byte temporizador2 = 81;           // Pino que liga o timer 2.
const byte temporizador3 = 82;           // Pino que liga o timer 3.
const byte temporizador4 = 83;           // Pino que liga o timer 4.
const byte temporizador5 = 84;           // Pino que liga o timer 5.
const byte solenoide1Pin = 85;           // Liga a reposicao de água doce.
const byte alimentadorPin = 86;          // Pino que controla o alimentador automático.
const byte skimmerPin = 87;              // Pino que controla o skimmer
