Forum Software Ferduino code Disable fan pin always ON
Post Number:#1 Post Thu Jan 12, 2017 12:19 pm
Topics: 9
Topics: 9
I did the 2 wire conection
Problem fans
the disable pin stay Always on...
try to change values on cooler configuration - 20º or 35º it activated
my skin temperature is 26º
i think i have a problem with disable pin... is Always on, no matter if i change the values on display
Last edited by Fernando Garcia on Thu Jan 12, 2017 12:33 pm, edited 1 time in total.
Reason: DO NOT use all letters in uppercase unless it's an abbreviation!
Post Number:#2 Post Thu Jan 12, 2017 12:33 pm
1 - DO NOT use all letters in uppercase unless it's an abbreviation!
viewtopic.php?f=20&t=22
2 - Check the instruction on code.
// Comente esta linha para desativar as mensagens no monitor serial ou para usar os pinos 0 e 1 (RX e TX) como OUTPUT
// Comment this line to disable the messages on serial monitor or to use pins 0 and 1 (RX e TX) as OUTPUT
#define DEBUG // Comente esta linha para usar os pinos 0 e 1 para controle dos coolers e buzzer.
Post Number:#3 Post Fri Jan 13, 2017 12:31 am
Topics: 9
Topics: 9
Post Number:#4 Post Fri Jan 13, 2017 9:22 am
Use latest version of Ferduino code, download the IDE 1.6.10 and follow this tutorial: viewtopic.php?f=8&t=34
