Forum Members section DIY Ferduino controller TFT with oscillation
TFT with oscillation  [SOLVED]
Post Number:#1 Post Thu Jul 21, 2016 10:01 am
Images: 38
Hello Fernando
My project is in final stage and I really appreciate the help that the forum has given me.
But I have found a new problems. The new problem is with oscillation in the TFT
I turn on the Arduino and the program starts the looping the TFT is oscillating.
This problema happens when I use a flat cable if I plug the TFT direct on the TFT shield that does not occur.
Could you tell me what I can do to solve this problem?
Post Number:#2 Post Thu Jul 21, 2016 11:07 am
It's bad contact, check your wiring.
I seen your image in gallery and I did two advices.
1 - This RTC is not compatible with Henning's library because has an EEPROM on board;
2 - The SDA and SCL should be 18 and 19 or 20 and 21 because the pins 4 and 5 are for touch screen.
Post Number:#3 Post Thu Jul 21, 2016 11:49 am
Images: 38
I'll check the contacts and return to you.
Thank you for seeing my gallery this problem I would treat after.
Which library should I use?
The orange wire is not connected to pins 4 and 5 he is not installed, however the picture looks.
Post Number:#4 Post Thu Jul 21, 2016 12:20 pm
You can use the "RTClib" by example but changes on code are needed.
If you are a newbie in programing maybe is better buy a new like this or a DS1307 without EEPROM.
The DS1302 is compatible with Henning's library according to an user here.
Here a DS1302 very cheap:
-------------------------------- Last edited Thu Jul 21, 2016 12:28 pm --------------------------------
Make sure that your flat cable is not missing a pin on center like this:
Post Number:#5 Post Fri Jul 22, 2016 11:15 am
Images: 38
Fernando
See my flat cable.
This face input in touch screen
This face input in TFT shield
I created this flat cable.
The problem may be occurring because:
- The cable is long?
- The cable is passing behind the power cables?
See my controller so you can better understand.
Outside
Inside
Video with problem
Post Number:#6 Post Fri Jul 22, 2016 11:47 am
Yes, the cable seems very long.
Cut out this remnant to decrease the length.
Post Number:#7 Post Tue Aug 09, 2016 10:50 am
Rafael, if this problem was solved please show us the solution and mark the topic as solved.
