Forum Software Ferduino code Code mode pumps alternated
Code mode pumps alternated  [SOLVED]
Post Number:#21 Post Tue Jul 19, 2016 5:13 pm
Topics: 22
Topics: 22
how can I make a video frame it if the pumps do not know if you can see I try maybe with the tester connected to the pump output
Post Number:#22 Post Tue Jul 19, 2016 6:57 pm
Topics: 22
Topics: 22
I try to explain it this way:
the PWM1 value is equal to 0 if they are in wavemaker screen for a time of 12 seconds
if you go will screen menu or menu inicio the PWM1 value of 0 for a time of just 5 seconds
pretty much the go more fast pumps depending on the screen
thank you
Post Number:#23 Post Tue Jul 19, 2016 7:04 pm
It's related with loop time as I told above.
Add:
Serial.println(millis());
After:
Serial.println(Pump1PWM);
And you will see the difference of time when is in wavemaker screen and other menus.
Post Number:#24 Post Wed Jul 20, 2016 5:33 pm
Topics: 22
Topics: 22
thank you
in fact both millis that PWM1 with the speeds are different if they are on screen inicio times are very fast
and then normal for displaying the graphic wavemaker everything slows down
it would take a more powerful arduiono
Post Number:#25 Post Wed Jul 20, 2016 6:44 pm
Change the "step_time" to 20 milliseconds it will increase the time that value of "Pump1PWM" remains in zero in home screen.
Post Number:#26 Post Thu Jul 21, 2016 3:01 am
Topics: 22
Topics: 22
thank you
a question the ferduino code could work with chipKIT Max32?
It should be more powerful than the Arduino Mega?
thank you
Post Number:#27 Post Thu Jul 21, 2016 11:14 am
With some changes it can work but the Arduino Due is better option.
Since the initial question seems solved can you mark this topic as solved clicking in "accept this answer"?
Post Number:#28 Post Thu Jul 21, 2016 3:58 pm
Topics: 22
Topics: 22
last thing if I use Arduino two can improve the performance?
for changing the speed of the pumps?
Post Number:#29 Post Thu Jul 21, 2016 4:19 pm
Yes, because Arduino DUE has clock speed of 84 MHz and Arduino Mega has 16 MHz.
I'm warning you since now there a TON of changes to make Ferduino work with Arduino DUE!
Post Number:#30 Post Thu Jul 21, 2016 4:58 pm
Topics: 22
Topics: 22
I thought that there was only the problem of 3.3v instead of 5v
but the codes are not to be already well?
Post Number:#31 Post Thu Jul 21, 2016 6:02 pm
Not at all!
Post Number:#32 Post Thu Jul 21, 2016 6:27 pm
Topics: 22
Topics: 22
You could say in general what is not compatible?
I read that the chipKIT Max32 also works with the codes of the mega
thank you
Post Number:#33 Post Thu Jul 21, 2016 6:38 pm
To start Arduino Due haven't an EEPROM.
If you want make Ferduino work with Arduino Due you should make it by yourself or ask help in Arduino forum.
Arduino Due or max32 are not in my part list so won't give support for it.
