Post Number:#301 Post Thu Dec 10, 2015 10:10 am
I didn't this board, I have only the project.
This board is very simple.
Post Number:#302 Post Thu Dec 10, 2015 10:54 am
Post Number:#303 Post Fri Dec 11, 2015 12:15 am
Post Number:#304 Post Fri Dec 11, 2015 11:36 pm
Post Number:#305 Post Sat Dec 12, 2015 3:33 am
how many PWM pins does Ferduino have, I want to control 4 jebao pumps (2 wave maker 2 dc return pumps), point is to use a single 24 volt by 450 watt power supply for all 4 pumps, also will make feed mode a lot easier and maintenance mode as well.
Post Number:#306 Post Sat Dec 12, 2015 10:38 am
on pin outs you have RJ-11 as one ground and one 5v, in board you have 2 gnd witch one is correct.
For this PCB the 5V is useless so, do not connect the wire in 5V.
The 5V is useful if you want add a LED on PCB.
There 15 PWM pins but, for DC pumps there only 2 free pins.
You needs use the pins reserved for LEDs or use a PWM expander as PCA9685.
Post Number:#307 Post Tue Dec 15, 2015 8:50 am
So I have ordered the I2c expansion, 24v 350 watt power supply and 2 jebao return pumps I will also convert my skimmer to a jebao pump as well as I will have the room to do it with the expansion. Kind of excited about this. Got my wp60 today, that thing is a monster and moves a lot of water.
Post Number:#308 Post Tue Dec 15, 2015 2:16 pm
Waiting to see it working. :)
Post Number:#309 Post Wed Dec 16, 2015 11:24 pm
Hi Fernando.
Do you have any thoughts on what the circuit will look like for using the board you have suggested, I have some stuff already worked out, but could use some help with details of things.
Post Number:#310 Post Thu Dec 17, 2015 7:48 am
The wiring is like this:
Post Number:#311 Post Thu Dec 17, 2015 7:49 am
From what I have found the circuit I need to build looks just like the one on the forum only it will have 6 out put connections, I will have one 24 volt+ bus to run all 5 pumps, on 24 v- connected in common with ferduino and pwm expansion, and the I2c communication on its own from ferduino. So I will need an LDD driver I thought I might. Will a LDD 350 be large enough my highest wattage is going to 105 watts, or should I use 1000 LDD? Or should I use this circuit for lights and LED pwm for motor control?
Post Number:#312 Post Thu Dec 17, 2015 8:01 am
Yes, is right.
In the image above the LDD is your PCB and the LED is your pump.
Post Number:#313 Post Thu Dec 17, 2015 8:04 am
Ok so I do not need LDD just the circuit board I have been working on. Just need to add connections for the other pumps. I will finish the board layout today can you look and see if missed any thing, your knowledge about this surpasses mine by far.
Post Number:#314 Post Fri Dec 18, 2015 10:22 am
For Jebao pumps the LDD is not needed.
This image is only to show the concept, I mean all GNDs connected and +24V and PWM going directly to your PCB.
Show me the project.
Post Number:#315 Post Fri Dec 18, 2015 11:00 am
Post Number:#316 Post Sat Dec 19, 2015 11:51 pm
Hi Fernando, what other I2c components will I have to program around, I have been reading up on how to do it, I would just like to know what I will be up against when my parts are all done. I am also going to make a separate screen for manual control of these pins as well thanks in advance for your support.
Post Number:#317 Post Sun Dec 20, 2015 10:42 am
The PCF8575 on I2C bus should work normally with this new device. No changes on code are needed for others devices.
Post Number:#318 Post Wed Dec 23, 2015 1:40 pm
Hi Fernando, I have to provide an I2c address fort his within the code only on setup as (0x40) correct?
-------------------------------- Last edited Wed Dec 23, 2015 10:50 am --------------------------------
Post Number:#319 Post Wed Dec 23, 2015 1:53 pm
Check this tutorial please: https://learn.adafruit.com/16-channel-pwm-servo-driver
A basic code for it is:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
  Serial.begin(9600);
  Serial.println("16 channel PWM test!");
  pwm.begin();
  pwm.setPWMFreq(1600);  // This is the maximum PWM frequency
  // Drive each PWM in a 'wave'
  for (uint16_t i=0; i<4096; i += 8)
    for (uint8_t pwmnum=0; pwmnum < 16; pwmnum++)
      pwm.setPWM(pwmnum, 0, (i + (4096/16)*pwmnum) % 4096 );
Post Number:#320 Post Wed Dec 23, 2015 2:00 pm
-------------------------------- Last edited Wed Dec 23, 2015 11:02 am --------------------------------
Even with that code being for servos it will work for pwm motor?
Users viewing this topic: SEMrush [Bot] and 0 guests
