Forum Software Ferduino code Graphics
Graphics
Post Number:#1 Post Sun Oct 18, 2015 6:11 am
Topics: 11
Images: 4
Topics: 11
Hello Fernando. I am not leaving temperature graphs only displays the actual temperature but without graphical . The SD card is 2gb and formatted and the card goes in the slot on the ITDB32wd screen .
Post Number:#2 Post Sun Oct 18, 2015 9:44 am
Which version of Ferduino code are using?
Have you tested the SD card with example available on forum?
Are you using this code in Ferduino tab?
const byte ChipSelect_SD = 53;
const byte SelectSlave_ETH = 4;
Post Number:#3 Post Sun Oct 18, 2015 5:31 pm
Topics: 11
Images: 4
Topics: 11
Post Number:#4 Post Sun Oct 18, 2015 5:40 pm
With example are you using this lines?
//const byte SelectSlave_SD = 4;
const byte SelectSlave_SD = 53;
const byte SelectSlave_RFM = 69;
Post Number:#5 Post Mon Oct 19, 2015 4:12 pm
Topics: 11
Images: 4
Topics: 11
Hello Fernando. I have just tested with the test codes, as thou sayest. And as that does not recognize anything; i said that connect the device, but is already connected. If i tried to see if he recognized the probes in the test code and if the recognized, but the sd does not. Is there to make some modifications in the plate?
Post Number:#6 Post Mon Oct 19, 2015 5:31 pm
Using test code for SD card the temperature sensor is not needed.
How is connected your TFT? A picture?
Post Number:#7 Post Tue Oct 20, 2015 10:23 am
Topics: 11
Images: 4
Topics: 11
Post Number:#8 Post Thu Oct 22, 2015 12:02 pm
Have you tested without screw schield?
There no short circuit between pins on header 2 x 18?
Post Number:#9 Post Thu Oct 22, 2015 4:52 pm
Topics: 11
Images: 4
Topics: 11
Hello Fernando. I have more photos ,now i tried without the shield screw, i see no short and everything else works fine, except the sd. When i do the test that you cannot open the sd. I still do not see the problem.
Post Number:#10 Post Thu Oct 22, 2015 8:29 pm
What you can see on serial monitor?
Post Number:#11 Post Fri Oct 23, 2015 3:50 am
Topics: 11
Images: 4
Topics: 11
Post Number:#12 Post Fri Oct 23, 2015 8:27 am
Forget it, I seen in codebender's image: "Can't open!".
Try change this variable:
SPI_HALF_SPEED
SPI_QUARTER_SPEED
Or:
SPI_FULL_SPEED
Post Number:#13 Post Fri Oct 23, 2015 6:18 pm
Topics: 11
Images: 4
Topics: 11
Hello Fernando.
I've tried changing by quarter or by full and also opens the sd. I've been looking through the code and i see what appears in the photo, this is not the same as puts in the test code.All right?
Post Number:#14 Post Fri Oct 23, 2015 6:54 pm
No matter if I'm calling a variable of "A" in a code and "B" in other. Try learn the function to each one.
Post Number:#15 Post Sat Oct 24, 2015 7:12 am
Topics: 11
Images: 4
Topics: 11
Forgives Fernando, if I understand how the code works for evidence, simply asked for sure. I have just tested with another screen with card reader, for if the other was evil and neither opens the SD. I am thinking of giving the driver without graphics because everything else works fine. Although I'd like to find the problem
