Forum Members section DIY Ferduino controller Which connect the LEDs?
Which connect the LEDs?  [SOLVED]
Post Number:#1 Post Fri Jun 12, 2015 8:12 am
Topics: 8
Images: 10
Topics: 8
Hi, the topic http://www.ferduino.com/forum/viewtopic.php?f=24&t=36 advises not to plug the pins 10, 11, 12 and 13. The LEDs will be connected in which pins?
And the white LED that is connected to the 10 but 10 is made a pro bridge 53?
It is connected beneath the plate with a welded wire?
Thank you.
Post Number:#2 Post Fri Jun 12, 2015 11:56 am
All pins for LED's are free on Arduino.
Connect the ethernet shield over the screw shield so, you can use the terminal blocks to connect the wires.
The order to connect the parts is: Arduino > Screw shield > Ethernet shield > TFT shield > TFT.
