Forum Software Ferduino code Problem with skimmer and dosing pumps.
Problem with skimmer and dosing pumps.  [SOLVED]
Post Number:#1 Post Wed Apr 29, 2015 6:30 pm
hi
some products that would add to the dosing pumps create interference with the skimmer, which begins to foam in an abundant and overflowing glass.
controller for turning the skimmer I used the code change as from this link
viewtopic.php?f=8&t=63&p=617&hilit=skimmer#p617
it is possible to stop the skimmer for a time when the dosing pumps fit products?
thanks a lot
Danilo Casteller
Post Number:#2 Post Thu Apr 30, 2015 11:54 am
Welcome Danilo!
Here you can add a flag (boolean) as:
if(i == 5) // i = 5 is dosing pump 6.
  flag = true;
On loop you can use the function millis to control the time as:
if(millis() - PreviousMillis) > 60000) // 60 seconds
 flag = false;
In check_level_skimmer() you can use:
 if((analogRead(sensor_skimmer) > 400) || (flag == true))
The code is incomplete, you need try learn a bit. :)
Post Number:#3 Post Sat May 02, 2015 12:21 pm
hi fernando
I have a question to ask
when dosing pumps are not working the variable "I" that I have difficulty in understanding it takes on value
it is possible to do a similar check
if ((dosadora1==higt) or (dosadora2==higt) or (dosadora3==higt)or(dosadora4==higt)or(dosadora5==higt)or(dosadora6==higt))
             flag= true
             flag=false
thank you very much for your patience
Post Number:#4 Post Sat May 02, 2015 1:41 pm
"i" is a variable local the value is between 0 and 5.
See on code:
for(byte i = 0; i < 6; i++)
i = 0 is pump 1;
i = 1 is pump 2;
And so on.
Check it: http://www.arduino.cc/en/Reference/For
If you want make the pause with all pumps this condition isn't needed.
  flag = true;
Only add:
flag = true;
Post Number:#5 Post Sat May 02, 2015 5:19 pm
hi
if I understand the code, so that interrupts the flow of the skimmer when the pump dosing work in automatic mode.
if instead act in manual, the flow of the skimmer is not interrupted right ??
Post Number:#6 Post Sat May 02, 2015 6:06 pm
For manual dosage you need work with this part: https://github.com/FernandoGarcia/Fedui ... .ino#L2393
Post Number:#7 Post Sun May 03, 2015 4:45 am
hello Fernando
I tried to make these changes but I can not run this change :(( :(( :(( :(( .
for the manual so I modified the code:
in processmytouch
 digitalWrite(dosadora[dosadora_selecionada], HIGH);
          verifica_dosometriche = false;
          delay(60000);
          digitalWrite(dosadora[dosadora_selecionada], LOW);
          verifica_dosometriche = true;
for automatic mode:
in dosadoras
tempo_dosagem = map (((dose_dosadora_personalizada_e[i] / quantidade_dose_dosadora_personalizada_e[i])*2), 0, fator_calib_dosadora_e[i], 0, 60000);
              tempo_dosagem /= 2;
              verifica_dosometriche =false;
              digitalWrite(dosadora[i], HIGH);
              delay(tempo_dosagem);
              digitalWrite(dosadora[i], LOW);
              verifica_dosometriche = true ;
the main page I added
boolean verifica_dosometriche= true;
the page loop
if (millis() - previousMillis > 60000) // 60 seconds
and finally the page Parámetros
void check_level_skimmer () // verifica livello skimmer
  if((analogRead(sensor3) < 400)||(verifica_dosometriche==false)   )
    digitalWrite(skimmerPin,LOW);
    digitalWrite(skimmerPin,HIGH);
~x( ~x( ~x( ~x( I can not understand if I'm wrong the point of insertion of commands or if they are just incorrect instructions :-\ :-\ :-\ :-\
thanks for the help ;) ;) ;)
Post Number:#8 Post Sun May 03, 2015 2:16 pm
This part is related with calibration so, this changes are useless.
          delay(60000);
This part is wrong!
              tempo_dosagem /= 2;
Delete this line:
After change the flag to false you need reset the time like this:
PreviousMillis = millis();
The variable "previousMillis" is used to others function you need create a new.
The logic here is wrong!
To turn on the skimmer again the variable "verifica_dosometriche" need be true.
See what you did here:
  if((analogRead(sensor3) < 400)||(verifica_dosometriche==false))
Post Number:#9 Post Thu May 28, 2015 5:24 pm
hello fernando
I tried and tried several times to change the code; but I can not understand where exactly do I have to change. can you help me understand where action
thank you very much and sorry for disturbing
Post Number:#10 Post Sat May 30, 2015 1:09 pm
Try this:
In the tab Ferduino add:
const byte sensor_skimmer = analog pin free; // No  need add it if you will use pins already declared on code
const byte skimmerPin = free pin; // No  need add it if you will use pins already declared on code
boolean dosage_done = false;
unsigned long wait_millis = 0;
const int wait = 10; // Time in minutes
On setup add:
pinMode(sensor_skimmer, INPUT);
pinMode(skimmerPin, OUTPUT);
In the tab "parametros" add:
void check_level_skimmer()
  if((analogRead(sensor_skimmer) > 400) || (dosage_done == true))
    digitalWrite(skimmerPin, LOW);
    digitalWrite(skimmerPin, HIGH);
On loop add:
if(dosage_done == true)
  if((millis() - wait_millis) > (wait * 60000))
check_level_skimmer();
In the tab "Dosadoras" add:
dosage_done = true;
wait_millis = millis();
After:
tempo_dosagem /= 2;
In the tab "ProcessMyTouch" add:
dosage_done = true;
After:
tempo_dosagem /= 2;
In the tab "Webserver" add:
dosage_done = true;
After:
tempo_dosagem /= 2;
Post Number:#11 Post Tue Jun 02, 2015 7:37 pm
hello fernando
thanks so much for your invaluable help.
changes to the code you entered work perfectly controlling the pumps in manual and through joyreef. but just now I noticed that in custom mode the pumps dosing. I tried to dose inserting either one as the number of doses that a number of higher doses over a period of 10 minutes but in no case the pumps are activated. You have no idea what it could be?
again thanks for the indispensable help from all of us
danilo casteller
-------------------------------- Last edited Wed Jun 03, 2015 12:13 am --------------------------------
hello fernando
I found the problem :D :D of default in the code that I downloaded the value dosadoras boolean = false; after changing into true works everything perfectly !!! :) :) :) :)
