Forum Members section DIY Ferduino controller Potentiometer mod for TFT shield question
Potentiometer mod for TFT shield question  [SOLVED]
Post Number:#1 Post Tue May 27, 2014 8:43 pm
Topics: 5
Topics: 5
Canada
Fernando
I am adding the potentiometer mod to the TFT shield like you showed in your TFT shield post.
I have a 1K multiturn pot, can I use it for this.
Also, when I test it should I start with the pot turned down low so I have just the 10 ohms from the supplied resistor.
Donato
Post Number:#2 Post Tue May 27, 2014 8:57 pm
You can but maybe you will need of more resistance.
No matter because the voltage never will be higher than 3.3V.
Post Number:#3 Post Tue May 27, 2014 10:05 pm
Topics: 5
Topics: 5
Canada
Fernando
I will try it first and if needed I will go and buy a 10K ohm pot to replace it.
Obrigado
Donato
Post Number:#4 Post Thu May 29, 2014 3:45 am
Show us your work when you are done with it :)
Post Number:#5 Post Thu May 29, 2014 10:14 pm
Topics: 5
Topics: 5
Canada
Simone
I'm still waiting for parts to come in but as soon as I get a chance I'll take a couple of pictures of the TFT shield
I think it has turned out well so far.
Take care
Donato
Post Number:#6 Post Sun Jun 15, 2014 3:24 pm
Please, give us a feedback about this question.
Post Number:#7 Post Sun Jun 15, 2014 7:50 pm
Topics: 5
Topics: 5
Canada
I will
I am going to take some pictures soon and will post them.
I did not want to post my work when I thought I had issues with the shield.
Regards
Donato
Post Number:#8 Post Thu Jun 26, 2014 1:06 am
Topics: 5
Topics: 5
Canada
Okay, finally got time to get it done so here we go.
First 2 images are how I prepared the potentiometer. I used a 10Kohm potentiometer, since it would add a much smaller load to the Arduino than the 5K, and one of the 10 ohm resistors in the kit.
Then I soldered the other 10 ohm resistor on the bottom of the board to allow room for the pot on top.
Then I soldered in the pot and resistor combo. front leg of pot goes in front hole and resistor leg goes in second hole.
third leg with green wire goes to ground pin. Then I used some hotglue to secure the back end of the pot.
this provided a nice low profile and didn't interfere with the stacking of the shields.
You will also notice that I soldered both legs of R16 to the board but removed pin 53.
I then soldered a wire from the leg of R16 to the leg of R32 that directly connects to pin 4
so far so good, board has tested good, though I had to use a IC2 scanner to get my RTC working correctly.
Regards
Donato
Post Number:#9 Post Thu Jun 26, 2014 9:52 am
Great work!
Thank you by feedback.
Mark this topic as solved if you haven't any problem about this.
Post Number:#10 Post Thu Jun 26, 2014 7:36 pm
excellent work, thank you for sharing
