Forum Members section Show your controller My build.
My build.
Post Number:#21 Post Mon Feb 02, 2015 7:13 am
Topics: 12
Topics: 12
Netherlands
Post Number:#22 Post Mon Feb 02, 2015 7:24 am
This relay can be used too but, maybe the noise "click click" will be annoying.
Post Number:#23 Post Thu Feb 05, 2015 3:49 am
Topics: 12
Topics: 12
Netherlands
I am now working on the PH stamp. I have the latest one sayin ezo on the bottom left. Does this stamp need some changes in the code? I now takes about a minute for the board to completely boot. You get a lot of flashing images during boot. Then it boots up en shows ph. But after say 30sec it will reboot itself all by itself and do again the same minute boot sequence.
Post Number:#24 Post Thu Feb 05, 2015 4:18 am
Post Number:#25 Post Thu Feb 05, 2015 6:19 am
Topics: 12
Topics: 12
Netherlands
Post Number:#26 Post Thu Feb 05, 2015 6:38 am
There are changes in other parts of the sketch as well, I'm not at home right now but I can look at mine and let you know what I find.
Post Number:#27 Post Thu Feb 05, 2015 6:46 am
Your stamp is working with test code?
Post Number:#28 Post Thu Feb 05, 2015 7:11 am
Topics: 12
Topics: 12
Netherlands
Post Number:#29 Post Thu Feb 05, 2015 8:01 am
Did you sent this to your stamp?
SERIAL,9600<CR>
What's the reason to change baud rate?
Why complicate your life?
Post Number:#30 Post Thu Feb 05, 2015 8:11 am
Post Number:#31 Post Thu Feb 05, 2015 8:23 am
The baud rate need be synchronized otherwise never will work.
I mean:
Serial.begin() with serial monitor;
Serial3.begin() with stamp.
Post Number:#32 Post Thu Feb 05, 2015 8:36 am
Could that be why my PH stamp was giving some different readings sometimes.
-------------------------------- Last edited Thu Feb 05, 2015 5:45 am --------------------------------
Post Number:#33 Post Thu Feb 05, 2015 8:56 am
Topics: 12
Topics: 12
Netherlands
Post Number:#34 Post Thu Feb 05, 2015 10:44 am
To be more simple, NOT!
Post Number:#35 Post Thu Feb 05, 2015 11:09 am
Topics: 12
Topics: 12
Netherlands
Post Number:#36 Post Thu Feb 05, 2015 11:15 am
Your code have this lines in Ferduino tab?
#define STAMPS_V4X // Comente esta linha para usar Stamps EZO
//#define STAMPS_EZO // Descomente esta linha para usar Stamps EZO
Post Number:#37 Post Thu Feb 05, 2015 11:49 am
Topics: 12
Topics: 12
Netherlands
Post Number:#38 Post Thu Feb 05, 2015 11:53 am
Change to:
//#define STAMPS_V4X // Comente esta linha para usar Stamps EZO
Post Number:#39 Post Thu Feb 05, 2015 7:05 pm
Topics: 12
Topics: 12
Netherlands
For now changing the serial3 baudrate to 9600 seems to do the trick. I will now research on how to change the buadrate of the stamp form 9600 to 38400.
Post Number:#40 Post Thu Feb 05, 2015 7:17 pm
Only set the serial monitor to carriage return and send SERIAL,38400
Users viewing this topic: SEMrush [Bot] and 1 guest
