Forum Software Ferduino code Code mode pumps alternated
Code mode pumps alternated  [SOLVED]
Post Number:#1 Post Sat Jan 31, 2015 2:53 pm
Topics: 22
Topics: 22
hello Fernado
I wanted to know if it was possible to create a way of wavemaker pumps alternated in this way
Pump 1: 0
pump 2: 0 to max then returns to 0
pump 1: 0 to max then returns to 0
pump 2: 0
and so on ....
I can not create the code
Post Number:#2 Post Sat Jan 31, 2015 3:29 pm
All is possible if you want.
Post Number:#3 Post Sun Feb 01, 2015 3:19 pm
Topics: 22
Topics: 22
Could you help me I did some tests but I do not work
thank you
Post Number:#4 Post Sun Feb 01, 2015 4:28 pm
Maybe, if you show me what you are doing.
Post Number:#5 Post Sun Feb 01, 2015 6:34 pm
Topics: 22
Topics: 22
    value = int(128 + 127 * sin(2  *  PI / periodo * times));
    Pump1PWM = 255 - value;
    Pump2PWM = 0;
    Pump1PWM = 0;
    Pump2PWM = 255 - value;
Post Number:#6 Post Sun Feb 01, 2015 10:04 pm
On this way Pump1PWM never will be different of zero.
You need add conditions to alternate between this two cases.
By example during how many seconds the values will be Pump1PWM = 255 - value and Pump2PWM = 0.
Adding a Serial.println(Pump1PWM); and Serial.println(Pump2PWM); can help you learn how it change of value.
Post Number:#7 Post Mon Feb 02, 2015 10:02 am
Topics: 22
Topics: 22
sorry I can not understand where I enter the Serial.println
Post Number:#8 Post Tue Feb 03, 2015 9:51 am
Topics: 22
Topics: 22
Could you help me?
thank you
Post Number:#9 Post Sat Apr 25, 2015 9:46 am
Topics: 22
Topics: 22
I did many tests but I can not do this function
please help me?
Post Number:#10 Post Fri Jun 26, 2015 3:04 am
Topics: 22
Topics: 22
but serialprint not need to write the messages on the display?
I can not understand how I should set up the command
Post Number:#11 Post Sun Jun 28, 2015 12:12 pm
Try learn the basic first.
Google it.
Post Number:#12 Post Sun Jul 26, 2015 2:00 pm
Topics: 22
Topics: 22
should I use a Millis right?
but I do not know how to set it up
help me?
Post Number:#13 Post Sat Sep 26, 2015 4:50 pm
Topics: 22
Topics: 22
do not help me please ???? :( :( :( ^:)^
Post Number:#14 Post Sun Sep 27, 2015 3:12 pm
After all this time let me see the code that you wrote.
Post Number:#15 Post Sun Sep 27, 2015 3:24 pm
Topics: 22
Topics: 22
I am still stuck to the code I posted above I do not know how to move forward and for this I ask help
thank you
Post Number:#16 Post Tue Sep 29, 2015 3:40 pm
I really think that you only want the code done.
Try this:
Ferduino tab:
// Global variables
unsigned long millis_step = 0;
byte step = 0;
int step_time = 1000; // milliseconds
Wavemaker tab:
  else if (modo_selecionado == 5)
    if (step == 0)
      if ((millis() - millis_step) > step_time)
        Pump1PWM += 1;
        Pump2PWM = 0;
        millis_step = millis();
      if (Pump1PWM == 255)
        step = 1;
    else if (step == 1)
        Pump1PWM -= 1;
        Pump2PWM = 0;
      if (Pump1PWM == 0)
        step = 2;
    else if (step == 2)
        Pump1PWM = 0;
        Pump2PWM += 1;
      if (Pump2PWM == 255)
        step = 3;
    else if (step == 3)
        Pump1PWM = 0;
        Pump2PWM -= 1;
      if (Pump2PWM == 0)
        step = 0;
It will replace manual mode so the buttons + and - on touch will be useless.
It's very basic and only with this tutorial is possible write this function: https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
Please do not ask me to make other custom function for you.
Post Number:#17 Post Mon Jul 18, 2016 6:13 pm
Topics: 22
Topics: 22
Thanks for your help
I wanted to decrease the step_time 1000 milliseconds to 10 millisecond to increase the speed of climb and descent
I located a problem if I'm okay in wavemaker screen works well if I move on the home screen does not keep him more step_time set but charged on a much more high speed and the pumps are only small movements
I controlled via serial monitor effects the speed of the count and very fast
I do not understand why it seems that outside the screen wavemaker does not take account of step_time
thank you
Post Number:#18 Post Tue Jul 19, 2016 10:36 am
I can't see any problem since 10 milliseconds is very fast even and the PWM keeps high during a small amount of time.
The speed seems smaller in wavemaker screen because the controller is spending time to update the screen all time and in home screen it doesn't happens.
Post Number:#19 Post Tue Jul 19, 2016 5:03 pm
Topics: 22
Topics: 22
I connected the pumps when they step to the start menu the pumps do not follow more times and go much faster do not know if I explained
if I use the mode 1 or 2 etc. the defect does not occur
step_time if I put it in 1000 operates all right
but quersto way pome go real slow I would like the mode 1 and 2 speed but if I lower the time to 10 I leave the screen in wavemaker works well if I go back to the home screen changes speeds very strong as if not taking the spet_time
Last edited by Simone Sandonati on Tue Jul 19, 2016 5:09 pm, edited 1 time in total.
Post Number:#20 Post Tue Jul 19, 2016 5:05 pm
I don't understand, a video can help.
