Post Number:#81 Post Tue Dec 30, 2014 4:09 am
ok so at his point faith restored I have been running the ferduino for a week now with out messing with it and it has done well, I will be getting on my tank in the next few days, just got my 5up and driver board tonight next will be the 48v power supply I have managed to work with the code enough to add some my own little things and Fernando thank you so much for being a great teacher and helping when necessary. :ymapplause: :ymhug:
Post Number:#82 Post Tue Dec 30, 2014 10:09 am
You're welcome.
Glad to hear.
Post Number:#83 Post Fri Jan 02, 2015 10:50 pm
Post Number:#84 Post Sat Jan 03, 2015 1:00 pm
Hi Christopher!
Happy New Year!
My holiday was very good, thanks.
I hope that your was too.
Post Number:#85 Post Tue Jan 06, 2015 6:42 am
Ok so I am still having problems with the network side of my controller but as for everything else it is working well. It is still coming up with a different IP than what is in the code, I have a 2gb memory card and have formatted with fat32, the TFT is hooked directly to the controller, I have tried to run the ethernet test code but I cannot get the html file to save to the card.
-------------------------------- Last edited Tue Jan 06, 2015 3:43 am --------------------------------
Post Number:#86 Post Tue Jan 06, 2015 5:41 pm
Topics: 11
Topics: 11
Ok so I am still having problems with the network side of my controller but as for everything else it is working well. It is still coming up with a different IP than what is in the code, I have a 2gb memory card and have formatted with fat32, the TFT is hooked directly to the controller, I have tried to run the ethernet test code but I cannot get the html file to save to the card. .
Have you tried fernandos test code for the network adapter (the one without the file for the sd card)
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177); // Change the IP according to your local network
const byte SelectSlave_ETH = 53;
EthernetServer server(80);
 // Open serial communications and wait for port to open:
  Serial.begin(9600);
   while (!Serial)
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, SelectSlave_ETH);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
void loop() {
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
     client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
          break;
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
I tried this one, with an ip for my local network and it worked. Opening up a web browser and typing the ip of the controller in brought some basic info on screen.
Can you post your network config section of your code?
Post Number:#87 Post Wed Jan 07, 2015 12:41 am
boolean Ethernet_Shield = true;           // Change to "false" if not an Ethernet Shield connected to the Arduino.
char *Username  = "*********";           // Put here the user name registered in the joy-reef.comconectado the Arduino.
char *APIKEY = "*******";                 // Stick the ApiKey generated by joy-reef.com
byte maxima_tentativa = 3;                // Número máximo de tentativas de autenticação.
unsigned long intervalo_tentativa = 15;   // Tempo  de espera (em minutos) para novas tentativas.
byte mac[] = {0xDE,0xAD,0xBE,0xEF,0xFE,0xED};         // Este MAC deve ser único na sua rede local.
byte ip[] = {192,168,0,140};              // Configure o IP conforme a sua rede local.
IPAddress dnsServer(8,8,8,8);             // Configure o IP conforme a sua rede local. Este é o DNS do Google, geralmente não é necessário mudar.
IPAddress gateway(192,168,0,1);           // Configure o "Gateway" conforme a sua rede local.
IPAddress subnet(255,255,255,0);          // Configure a máscara de rede conforme a sua rede local.
EthernetServer server(9000);              // Coloque aqui o número da porta configurada no seu roteador para redirecionamento.
this is what you were talking about or do you mean the tab, also I am using ferduino mega 2560.
void processRequest()
  char clientline[110];
  char line[110];
  char *requestString;
  char *RequestString;
  byte index = 0;
  uint8_t remoteIP[4];
  IPAddress joyreef(178, 255, 75, 60);
  client.getRemoteIP(remoteIP);
  if (client)
    Serial.print(remoteIP[0]);
    Serial.print(".");
    Serial.print(remoteIP[1]);
    Serial.print(".");
    Serial.print(remoteIP[2]);
    Serial.print(".");
    Serial.println(remoteIP[3]);
    if(((remoteIP[0] == joyreef[0]) && (remoteIP[1] == joyreef[1]) && (remoteIP[2] == joyreef[2]) && (remoteIP[3] == joyreef[3])) ||
      ((remoteIP[0] == ip[0]) && (remoteIP[1] == ip[1]) && (remoteIP[2] == ip[2])))
          if (c != '\n' && c != '\r')
            if(index < 110)
              clientline[index] = c;
              line[index] = c;
              index++;
            continue;
          clientline[index] = 0;
          line[index] = 0;
          Serial.println(clientline);
          if (strstr(clientline, "GET /"))
            if(strstr(clientline,"?"))
              //ignore any page request just look at the GET
              requestString = strstr(clientline,"=") + 1;
              (strstr(clientline, " HTTP"))[0] = 0;
              RequestString = strstr(line,"=") + 1;
              (strstr(line, " HTTP"))[0] = 0;
              readRequest(requestString, RequestString);
          break;
    delay(2);
    client.stop();
void readRequest(char *request, char *Request)
  char inData[50];
  byte count = 0;
  char *str;
  char *p;
  boolean invalidPass = true;
  char *pass;
  boolean terminador = false;
  char credencial[50];
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[8]))); // "HTTP/1.1 200 OK"
  client.println(buffer);
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[9]))); // "Content-Type: application/json"
  client.println();
  pass = strtok(Request, ",");
  base64_decode(pass, pass, strlen(pass));
  base64_decode(credencial, Auth1, strlen(Auth1));
  invalidPass = strcmp (pass, credencial);
  requestString = strstr(request,",") + 1;
  if (invalidPass  == false)
    for(int j = 0; j < strlen(requestString); j++)
      if(request[j]!='K')
        inData[j] = requestString[j];
      if(requestString[j] == 'K')
        inData[j] = '\0';
        p = inData;
        terminador = true;
        while ((str = strtok_r(p, ",", &p)) != NULL)
          inParse[count] = str;
          count++;
  if ((invalidPass  == false) && (tentativa < maxima_tentativa) && (terminador == true))
    tentativa = 0;
    requestAction(atoi(inParse[0]));
    tentativa++;
    if(tentativa <= maxima_tentativa)
      intervalo = millis();
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[10]))); // "{\"response\":\"000\"}"
      client.print(buffer);
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[11]))); // "{\"response\":\"001\",\"interval\":\""
      client.print(buffer + String((intervalo_tentativa * 60) - ((millis() - intervalo) / 1000)) +  "\"}");
    delay(2);
    client.stop();
void requestAction(byte ID)
  byte cont = 0;
  byte dia;
  float lunarCycle = moonPhase(t.year, t.mon, t.date); //get a value for the lunar cycle
    switch (ID)
  case 0: // Home
    client.print(F("{\"theatsink\":"));
    client.print(tempH);
    client.print(F(",\"twater\":"));
    client.print(tempC);
    client.print(F(",\"tamb\":"));
    client.print(tempA);
    client.print(F(",\"waterph\":"));
    client.print(PHA);
    client.print(F(",\"reactorph\":"));
    client.print(PHR);
    client.print(F(",\"orp\":"));
    client.print(ORP);
    client.print(F(",\"dens\":"));
    client.print(DEN);
    client.print(F(",\"wLedW\":"));
    client.print(LedToPercent(wled_out));
    client.print(F(",\"bLedW\":"));
    client.print(LedToPercent(bled_out));
    client.print(F(",\"rbLedW\":"));
    client.print(LedToPercent(rbled_out));
    client.print(F(",\"redLedW\":"));
    client.print(LedToPercent(rled_out));
    client.print(F(",\"uvLedW\":"));
    client.print(LedToPercent(uvled_out));
    client.print(F(",\"unix\":"));
    client.print(rtc.getTimeStamp());
    client.print(F(",\"running\":"));
    client.print(millis()/1000);
    client.print(F(",\"speed\":"));
    client.print(LedToPercent(fanSpeed));
    client.print(F(",\"moonPhase\":"));
    client.print(fase);
    client.print(F(",\"iluminated\":"));
    client.print(lunarCycle *100);
    client.print(F("}"));
    break;
  case 1:
    //  Send{case, mode, association}
    if (atoi(inParse[1]) == 0) // mode = 0 to read values
      byte numberOfDevices = 0;
      float temperatura1 = 0;
      float temperatura2 = 0;
      float temperatura3 = 0;
      sensors.begin();
      numberOfDevices = sensors.getDeviceCount();
      for(byte k = 0; k < numberOfDevices; k++)
        // Pesquisar endereços
        if(sensors.getAddress(tempDeviceAddress, k))
          if (k == 0)
            temperatura1 = sensors.getTempC(tempDeviceAddress);
            for (byte i=0; i<8; i++)
              sonda1[i] = tempDeviceAddress[i];
          if (k == 1)
            temperatura2 = sensors.getTempC(tempDeviceAddress);
              sonda2[i] = tempDeviceAddress[i];
          if (k == 2)
            temperatura3 = sensors.getTempC(tempDeviceAddress);
            for (byte i = 0; i < 8; i++)
              sonda3[i] = tempDeviceAddress[i];
      client.print(F("{\"number\":"));
      client.print(numberOfDevices);
      if(numberOfDevices < 2)
        if(sonda_associada_1 == 1)
          sonda_associada_2 = 0;
          sonda_associada_3 = 0;
        else if(sonda_associada_2 == 1)
          sonda_associada_1 = 0;
        else if(sonda_associada_3 == 1)
      client.print(F(",\"p1\":"));
      client.print(temperatura1);
      client.print(F(",\"p2\":"));
      client.print(temperatura2);
      client.print(F(",\"p3\":"));
      client.print(temperatura3);
      client.print(F(",\"ap1\":"));
      client.print(sonda_associada_1);
      client.print(F(",\"ap2\":"));
      client.print(sonda_associada_2);
      client.print(F(",\"ap3\":"));
      client.print(sonda_associada_3);
      client.println(F("}"));
    else if (atoi(inParse[1]) == 1) // mode = 1 to save values
      sonda_associada_1 = atoi(inParse[2]); // 0,3,2,K
      sonda_associada_2 = atoi(inParse[3]);
      sonda_associada_3 = atoi(inParse[4]);
      for(byte i = 0; i < 8; i++)
          sensor_agua[i] = sonda1[i];
        else if(sonda_associada_1 == 2)
          sensor_agua[i] = sonda2[i];
          sensor_agua[i] = sonda3[i];
          sensor_dissipador[i] = sonda1[i];
        else if(sonda_associada_2 == 2)
          sensor_dissipador[i] = sonda2[i];
          sensor_dissipador[i] = sonda3[i];
          sensor_ambiente[i] = sonda1[i];
        else if(sonda_associada_3 == 2)
          sensor_ambiente[i] = sonda2[i];
          sensor_ambiente[i] = sonda3[i];
      contador_temp = 0;
      temperatura_agua_temp = 0;
      temperatura_dissipador_temp = 0;
      temperatura_ambiente_temp = 0;
      sensors.requestTemperatures();   // Chamada para todos os sensores.
      tempC = (sensors.getTempC(sensor_agua));  // Lê a temperatura da água
      tempH = (sensors.getTempC(sensor_dissipador)); // Lê a temperatura do dissipador.
      tempA = (sensors.getTempC(sensor_ambiente)); // Lê a temperatura do ambiente.
      SaveDallasAddress();
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[7]))); // "{\"response\":\"ok\"}"
    break;
  case 2: //config date & time //Send (case, mode, date, month, year, hour, minute, second, day of week)
    if(atoi(inParse[1]) == 0) // To save time and date send inParse[1] = 1
      client.print(F("{\"date\":\""));
      client.print(t.year);
      client.print(F("-"));
      client.print(t.mon);
      client.print(t.date);
      client.print(F("\",\"time\":\""));
      client.print(t.hour);
      client.print(F(":"));
      client.print(t.min);
      client.print(t.sec);
      client.print(F("\"}"));
      dia = validateDate(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2]));
      dia = validateDateForMonth(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2]));
      rtc.halt(true);
      rtc.setDate(dia, atoi(inParse[3]), atoi(inParse[2]));
      rtc.setTime(atoi(inParse[5]), atoi(inParse[6]), atoi(inParse[7]));
      rtc.setDOW(calcDOW(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2])));
      rtc.halt(false);
    break;
  case 3:
    if(atoi(inParse[1]) == 0) // Send (case, mode, values)
      client.print(F("{\"hour\":"));
      client.print(hora);
      client.print(F(",\"minute\":"));
      client.print(minuto);
      client.print(F(",\"duration\":"));
      client.print(duracaomaximatpa);
      client.print(F(",\"monday\":"));
      client.print(segunda);
      client.print(F(",\"tuesday\":"));
      client.print(terca);
      client.print(F(",\"wednesday\":"));
      client.print(quarta);
      client.print(F(",\"thursday\":"));
      client.print(quinta);
      client.print(F(",\"friday\":"));
      client.print(sexta);
      client.print(F(",\"saturday\":"));
      client.print(sabado);
      client.print(F(",\"sunday\":"));
      client.print(domingo);
      client.print(F(",\"status\":"));
      client.print(bitRead(tpa_status,2));
    if(atoi(inParse[1]) == 1)
      hora = atoi(inParse[2]);
      minuto = atoi(inParse[3]);
      duracaomaximatpa = atoi(inParse[4]);
      segunda = atoi(inParse[5]);
      terca = atoi(inParse[6]);
      quarta = atoi(inParse[7]);
      quinta = atoi(inParse[8]);
      sexta = atoi(inParse[9]);
      sabado = atoi(inParse[10]);
      domingo = atoi(inParse[11]);
      SalvartpaEEPROM();
    if(atoi(inParse[1]) == 2)
      bitWrite(tpa_status,2,atoi(inParse[2]));
      Salvar_erro_tpa_EEPROM();
    break;
  case 4:    //individual led test - load first values
    if (atoi(inParse[1]) == 0) //Send (case, mode, wled, rled, rbled, rled, uvled)
      client.print(F("{\"wLedW\":"));
      client.print(wled_out);
      client.print(bled_out);
      client.print(rbled_out);
      client.print(uvled_out);
      client.print(rled_out);
    else if (atoi(inParse[1]) == 1) // mode = 1 to change values
      wled_out_temp = atoi(inParse[2]);
      bled_out_temp = atoi(inParse[3]);
      rbled_out_temp = atoi(inParse[4]);
      rled_out_temp = atoi(inParse[5]);
      uvled_out_temp = atoi(inParse[6]);
      web_teste = true;
      teste_led_millis = millis();
      teste_em_andamento = true;
    else if (atoi(inParse[1]) == 2)
      web_teste = false;
      teste_em_andamento = false;
      ler_predefinido_EEPROM();
    break;
  case 5:
    //  Send{case, mode, color, first position}
      client.print(F("{\"value0\":"));
      for(byte i = 1 + atoi(inParse[3]); i < 9 + atoi(inParse[3]); i++)
        client.print(cor[atoi(inParse[2])][i - 1]);
        if(i < 8 + atoi(inParse[3]))
          client.print(",\"value" + String(i - atoi(inParse[3])) + "\":");
    else if (atoi(inParse[1]) == 1) // mode = 1 to save values temporarily
      for (int i = atoi(inParse[3]); i < atoi(inParse[3]) + 8; i++)
        cont++;
        cor[atoi(inParse[2])][i] = atoi(inParse[3 + cont]);
    else if (atoi(inParse[1]) == 2) // mode = 2 to save values to eeprom
      SaveLEDToEEPROM();
    else if (atoi(inParse[1]) == 3) // mode = 3 to discard values
      ReadFromEEPROM();
    break;
  case 6: //moonlight
    //  Send{case, mode, value}
      client.print(F("{\"min\":"));
      client.print(MinI);
      client.print(F(",\"max\":"));
      client.print(MaxI);
      MinI = atoi(inParse[2]);
      MaxI = atoi(inParse[3]);
      Salvar_luz_noturna_EEPROM();
    break;
  case 7: //fan led
      client.print(F("{\"minfan\":"));
      client.print(HtempMin);
      client.print(F(",\"maxfan\":"));
      client.print(HtempMax);
      HtempMin = atof(inParse[2]);
      HtempMax = atof(inParse[3]);
      salvar_coolersEEPROM();
    break;
  case 8: //reduce led power
      client.print(F("{\"templimit\":"));
      client.print(tempHR);
      client.print(F(",\"potred\":"));
      client.print(potR);
      tempHR = atoi(inParse[2]);
      potR = atoi(inParse[3]);
      salvar_tempPotEEPROM();
    break;
  case 9: //water temperature control
      client.print(F("{\"setTemp\":"));
      client.print(setTempC);
      client.print(F(",\"offTemp\":"));
      client.print(offTempC);
      client.print(F(",\"alarmTemp\":"));
      client.print(alarmTempC);
      setTempC = atof(inParse[2]);
      offTempC = atof(inParse[3]);
      alarmTempC = atof(inParse[4]);
      SaveTempToEEPROM();
    break;
  case 10:// dosage manual
    // send (case, dosing pump selected, dose)
    dosadora_selecionada = atoi(inParse[1]);
    tempo_dosagem = map ((atof(inParse[2])*2), 0, fator_calib_dosadora[dosadora_selecionada], 0, 60000);
    tempo_dosagem /= 2;
    web_dosage = true;
    client.print("{\"wait\":" + String((tempo_dosagem / 1000) + 10) + "}");
    millis_dosagem = millis();
    break;
  case 11:// Calibration
    if(atoi(inParse[1]) == 0)// send (case, mode, dosing pump selected)
      dosadora_selecionada = atoi(inParse[2]);
      config_valores_calib_temp();
      client.print(F("{\"calib\":"));
      client.print(fator_calib_dosadora[dosadora_selecionada]);
    else if(atoi(inParse[1]) == 1)// send (case, mode, dosing pump selected) mode = 1 to dose
      client.print(F("{\"wait\":70}"));
      web_calibracao = true;
    else if(atoi(inParse[1]) == 2)// send (case, mode, dosing pump selected, factor of calibration) mode = 2 to save
      fator_calib_dosadora[dosadora_selecionada] = atof(inParse[3]);
      fator_calib_dosadora_1 = fator_calib_dosadora[0];
      fator_calib_dosadora_2 = fator_calib_dosadora[1];
      fator_calib_dosadora_3 = fator_calib_dosadora[2];
      fator_calib_dosadora_4 = fator_calib_dosadora[3];
      fator_calib_dosadora_5 = fator_calib_dosadora[4];
      fator_calib_dosadora_6 = fator_calib_dosadora[5];
      Salvar_calib_dosadora_EEPROM();
    break;
  case 12:
    if(atoi(inParse[1]) == 0) // Send (case, mode, dosing pump selected)
      config_valores_dosadoras_temp();
      config_valores_dosadoras_temp2();
      client.print(F("{\"hStart\":"));
      client.print(hora_inicial_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"mStart\":"));
      client.print(minuto_inicial_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"hEnd\":"));
      client.print(hora_final_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"mEnd\":"));
      client.print(minuto_final_dosagem_personalizada[dosadora_selecionada]);
      client.print(segunda_dosagem_personalizada[dosadora_selecionada]);
      client.print(terca_dosagem_personalizada[dosadora_selecionada]);
      client.print(quarta_dosagem_personalizada[dosadora_selecionada]);
      client.print(quinta_dosagem_personalizada[dosadora_selecionada]);
      client.print(sexta_dosagem_personalizada[dosadora_selecionada]);
      client.print(sabado_dosagem_personalizada[dosadora_selecionada]);
      client.print(domingo_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"quantity\":"));
      client.print(quantidade_dose_dosadora_personalizada[dosadora_selecionada]);
      client.print(F(",\"dose\":"));
      client.print(dose_dosadora_personalizada[dosadora_selecionada]);
      client.print(F(",\"onoff\":"));
      client.print(modo_personalizado_on[dosadora_selecionada]);
    else if(atoi(inParse[1]) == 1) // Send (case, mode, dosing pump selected, values)
      hora_inicial_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[3]);
      minuto_inicial_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[4]);
      hora_final_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[5]);
      minuto_final_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[6]);
      segunda_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[7]);
      terca_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[8]);
      quarta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[9]);
      quinta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[10]);
      sexta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[11]);
      sabado_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[12]);
      domingo_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[13]);
      quantidade_dose_dosadora_personalizada[dosadora_selecionada] = atoi(inParse[14]);
      dose_dosadora_personalizada[dosadora_selecionada] = atof(inParse[15]);
      modo_personalizado_on[dosadora_selecionada] = atoi(inParse[16]);
      config_valores_salvar_dosadoras();
      criar_arquivos();
      Salvar_dosadora_EEPROM();
    break;
  case 13: //PH control
      client.print(F("{\"setPHA\":"));
      client.print(setPHA);
      client.print(F(",\"offPHA\":"));
      client.print(offPHA);
      client.print(F(",\"alarmPHA\":"));
      client.print(alarmPHA);
      setPHA = atof(inParse[2]);
      offPHA = atof(inParse[3]);
      alarmPHA = atof(inParse[4]);
      SavePHAToEEPROM();
    break;
  case 14: // Calcium Reactor PH control
      client.print(F("{\"setPHR\":"));
      client.print(setPHR);
      client.print(F(",\"offPHR\":"));
      client.print(offPHR);
      client.print(F(",\"alarmPHR\":"));
      client.print(alarmPHR);
      setPHR = atof(inParse[2]);
      offPHR = atof(inParse[3]);
      alarmPHR = atof(inParse[4]);
      SavePHRToEEPROM();
    break;
  case 15: // ORP control
      client.print(F("{\"setORP\":"));
      client.print(setORP);
      client.print(F(",\"offORP\":"));
      client.print(offORP);
      client.print(F(",\"alarmORP\":"));
      client.print(alarmORP);
      setORP = atoi(inParse[2]);
      offORP = atoi(inParse[3]);
      alarmORP = atoi(inParse[4]);
      SaveORPToEEPROM();
    break;
  case 16: // Density control
      client.print(F("{\"setDEN\":"));
      client.print(setDEN);
      client.print(F(",\"offDEN\":"));
      client.print(offDEN);
      client.print(F(",\"alarmDEN\":"));
      client.print(alarmDEN);
      setDEN = atoi(inParse[2]);
      offDEN = atoi(inParse[3]);
      alarmDEN = atoi(inParse[4]);
      SaveDENToEEPROM();
    break;
  case 17:
    break;
  case 18:// Timers
    if(atoi(inParse[1]) == 0)// send (case, mode, timer selec.)
      temporizador = atoi(inParse[2]);
      config_valores_timers_temp();
      client.print(on_hora[temporizador]);
      client.print(on_minuto[temporizador]);
      client.print(off_hora[temporizador]);
      client.print(off_minuto[temporizador]);
      client.print(F(",\"activated\":"));
      client.print(temporizador_ativado[temporizador]);
    else if(atoi(inParse[1]) == 1)// send (case, mode, timer selected, values) mode = 1 to save
      web_timer = true;
      on_hora[temporizador] = atoi(inParse[3]);
      on_minuto[temporizador] = atoi(inParse[4]);
      off_hora[temporizador] = atoi(inParse[5]);
      off_minuto[temporizador] = atoi(inParse[6]);
      temporizador_ativado[temporizador] = atoi(inParse[7]);
      config_valores_salvar_timers();
      salvar_timers_EEPROM();
      bitWrite(temporizador_modificado,(temporizador + 1),1);
    break;
void dosagem_manual()
  digitalWrite(dosadora[dosadora_selecionada], HIGH);
  delay(tempo_dosagem);
  digitalWrite(dosadora[dosadora_selecionada], LOW);
void calibrar()
  delay(60000);
void enviar_dados()
  char dados[6];
  EthernetClient client;
  IPAddress joyreef(178, 255, 75, 58);
  String OneString;
  int ContentLength = 0;
  OneString = Username;
  ContentLength += OneString.length();
  dtostrf(tempC,5,2,dados);
  OneString = String(dados);
  dtostrf(tempH,5,2,dados);
  dtostrf(tempA,5,2,dados);
  dtostrf(PHA,5,2,dados);
  dtostrf(PHR,5,2,dados);
  OneString = String(DEN);
  OneString = String(ORP);
  OneString = String(rtc.getTimeStamp());
  ContentLength += 140;
  Serial.println(F("Connecting..."));
  if (client.connect(joyreef, 80))
    Serial.println(F(">> Connected <<"));
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[0]))); // "POST /api/temp HTTP/1.1"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[1]))); // "Host: www.joy-reef.eu"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[2]))); // "Authorization: Basic "
    client.println(Auth1);
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[3]))); // "Cache-Control: no-cache"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[4]))); // "Content-Type: application/x-www-form-urlencoded"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[5]))); // "Connection: close"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[6]))); // "Content-Length: "
    client.println(ContentLength);
    client.println();
    client.print(F("{\"userName\":\""));
    client.print(Username);
    client.print(F("\",\"minute\":\""));
    client.print(F("\",\"A\":")); // Temp. da água
    client.print(dtostrf(tempC,5,2,dados));
    client.print(F(",\"B\":")); // Temp. dissipador
    client.print(dtostrf(tempH,5,2,dados));
    client.print(F(",\"C\":")); // Temp. ambiente
    client.print(dtostrf(tempA,5,2,dados));
    client.print(F(",\"D\":")); // PH do aquário
    client.print(dtostrf(PHA,4,2,dados));
    client.print(F(",\"E\":")); // PH do reator de cálcio
    client.print(dtostrf(PHR,4,2,dados));
    client.print(F(",\"F\":")); // Densidade
    client.print(DEN);
    client.print(F(",\"G\":")); // ORP
    client.print(ORP);
    client.print(F(",\"H\":")); // Status chiller, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,0));
    client.print(F(",\"I\":")); // Status aquecedor, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,1));
    client.print(F(",\"J\":")); // Status reator de cálcio, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,5));
    client.print(F(",\"K\":")); // Status ozonizador, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,7));
    client.print(F(",\"L\":")); // Status reposição de água doce, 0 = desligado e 1 = ligado
    client.print(bitRead(Status,1));
    client.print(F(",\"M\":")); // Status niveis, 0 = baixo e 1 = normal
    client.print(nivel_status);
    client.print(F(",\"N\":")); // Status TPA, 0 = desligado e 1 = ligado
    client.print(bitRead(tpa_status,0));
    client.print(F(",\"O\":"));
    client.print(bitRead(temporizador_status,1)); // Status timer 1, 0 = desligado e 1 = ligado
    client.print(F(",\"P\":"));
    client.print(bitRead(temporizador_status,2)); // Status timer 2, 0 = desligado e 1 = ligado
    client.print(F(",\"Q\":"));
    client.print(bitRead(temporizador_status,3)); // Status timer 3, 0 = desligado e 1 = ligado
    client.print(F(",\"R\":"));
    client.print(bitRead(temporizador_status,4)); // Status timer 4, 0 = desligado e 1 = ligado
    client.print(F(",\"S\":"));
    client.print(bitRead(temporizador_status,5)); // Status timer 5, 0 = desligado e 1 = ligado
    client.print(F(",\"T\":")); // Sinaliza falha na TPA
    delay(5);
    client.stop();
    Serial.println(F("Can't connect!"));
also test code did not work for me just came back with server at 0.0.0.0.
Post Number:#88 Post Wed Jan 07, 2015 4:33 am
Topics: 11
Topics: 11
All looks similar to mine so not sure. Mine seems to have spaces after the , in the ip address and dns settings etc, don't know if that has anything to do with it. Have you also tried assigning a different ip like 192.168.0.24 etc. Does it work to log onto your router with 192.168.0.1?
Post Number:#89 Post Thu Jan 08, 2015 1:18 am
Hello Guy,
I have the standard login for my router, tried adding in the spaces and no change, so I tried some thing else I tuned off my power supply and reset low and behold the IP changed again as soon as I reconnect every thing it goes back to server IP as 64.128.0.132. not sure what is going on or why.
-------------------------------- Last edited Wed Jan 07, 2015 10:21 pm --------------------------------
Hi Fernando.
Sorry I did not make it on this morning I got forced into working over and did not get home till well after noon my time.
Post Number:#90 Post Sun Jan 11, 2015 6:06 am
Topics: 11
Topics: 11
Post Number:#91 Post Wed Jan 14, 2015 9:52 am
No not yet I was very busy this weekend plus my wife is sick soI had the kkids. Going to try this evening if I have time.
-------------------------------- Last edited Wed Jan 14, 2015 6:52 am --------------------------------
Post Number:#92 Post Fri Jan 16, 2015 9:57 am
Topics: 11
Topics: 11
Post Number:#93 Post Fri Jan 16, 2015 10:51 pm
Wife is all better now back to work she was sick for around three weeks, (brutal). any how Fernando I could sure use your help on this one. I noticed in one of the videos that you posted you are using 12 volt power, Any time I would use 12 volt power the board would start to have problems after a while and would get very hot even with a fan, that being said I have not used more than 9 volts. some of the issues I seam to be having are coming with the voltage changes :-s I will be home around 10:00 or 11:00 tomorrow if can offer any advice that would be great Fernando if you have any thoughts of what would be the issue could you PM me thanks. :-?
Post Number:#94 Post Fri Jan 16, 2015 11:01 pm
Low voltage on 5V circuit is related with overheating.
As you have a PC power supply you can use 5V connected directly on 5V pin and 12V separated to relay board. On this case the GND is common to both so, no problem.
Post Number:#95 Post Fri Jan 16, 2015 11:53 pm
wow Fernando you are up late thank you for the reply. Okay so ferduino is on a 5v line and an relay board is on a 5v line separate ground is common between the two, my relay board is only 5 volt not 12 volt, so all is good there. now a new issue if I unplug the USB from my pc ferduino tells to insert sd card witch is already installed. okay so I put in 4GB sd card and it worked fine also used VIN on db 25 and power issue went away. does it matter how the card is formatted.
Post Number:#96 Post Sat Jan 17, 2015 12:13 am
Yes, because I need talk with chinese company and the difference of time is 10 hours :(.
If your relay board work with 5V you need use an external power supply because the Ferduino's regulator can supply only 800 mA. Unless that you connect the power supply directly on 5v and it will bypass the regulator.
If the voltage drop the 3.3V circuits will not work fine.
Post Number:#97 Post Sat Jan 17, 2015 12:28 am
Post Number:#98 Post Sat Jan 17, 2015 9:02 am
Check the voltage on 5 V circuit when the USB is disconnected.
Post Number:#99 Post Sat Jan 17, 2015 10:56 am
Is 4.78 volts
-------------------------------- Last edited Sat Jan 17, 2015 8:00 am --------------------------------
Is 4.78 volts
Post Number:#100 Post Sat Jan 17, 2015 11:57 am
I had a problem with my ITDB32S and SD card.
I solved just adding a shunt on TFT to bypasses the regulator. See the image:
This happens because Ferduino have 3.3 V on TFT header and on TFT after the regulator the voltage is smaller so, the SD doesn't work fine.
But this problem doesn't happens with my ITDB32WD.
You can check the voltage on your TFT after the regulator and if needed add a shunt on pad called R4.
See the schematic:
http://itead-europe.com/pm/display/tft/ ... 02_4.3.pdf
Users viewing this topic: No registered users and 9 guests
