hello
you must forgive me but I do not know much about programming
I wanted to ask you can make a kind of screensaver?
when for a certain period of time is not touched, the display turns off
#include <UTFT.h>
#include <UTouch.h>
#include <DS1307henning.h>
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFontPlus[];
unsigned long previousMillis_1 = 0;
unsigned long previousMillis_2 = 0;
int interval = 20; // In seconds
UTFT myGLCD(ITDB32WD,38,39,40,41);
// UTouch      myTouch(6,5,4,3,2); // For DIY controller
UTouch      myTouch(7,6,5,4,3);    // For Ferduino Mega 2560
//       (SDA,SCL)
//DS1307 rtc(20, 21); // For DIY controller
DS1307 rtc(18, 19); // For Ferduino Mega 2560
Time t_temp, t;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  rtc.halt(false);
  mainScreen();
  previousMillis_1 = millis();
  if(myTouch.dataAvailable())
    myGLCD.clrScr();
    myGLCD.setFont(BigFont);
    myGLCD.setColor(255, 0, 0);
    myGLCD.print("Touch received!", CENTER, 110);
    delay(1000);
    previousMillis_2 = millis();
  if((millis() - previousMillis_1) > 5000)
    if((millis() - previousMillis_2) > interval * 1000)
      clockScreen();
      mainScreen();
void mainScreen()
  myGLCD.clrScr();
  myGLCD.setColor(255, 255, 255);
  myGLCD.print("Waiting for touch...", CENTER, 110);
  myGLCD.setColor(0, 255, 0);
  myGLCD.print("0 degrees", 0, 0, 0);
  myGLCD.print("90 degrees", 399, 0, 90);
  myGLCD.print("180 degrees", 399, 239, 180);
  myGLCD.print("270 degrees", 0, 239, 270);
void clockScreen()
  myGLCD.clrScr();
  myGLCD.setFont(SevenSegNumFontPlus);
  myGLCD.setColor(0, 174, 255);
  myGLCD.print(rtc.getTimeStr(FORMAT_LONG), CENTER, 100);
      clockScreen();
      mainScreen();
int dispScreen = 0;
void clockScreen()
  myGLCD.clrScr();
processMyTouch();
    if(((millis() - previousMillis_2) > interval * 1000) && (dispScreen == 0))
      clearScreen();
      mainScreen(true);
      processMyTouch();
mainScreen();
        clockScreen();
        mainScreen();
int interval = 35; // In seconds
