Forum Software Ferduino code Trouble with "refreshAll"
Trouble with "refreshAll"  [SOLVED]
Post Number:#1 Post Mon May 27, 2019 2:56 pm
Topics: 5
Topics: 5
Hello Fernando,
I have been reviewing and learning many things for several days thanks to your extensive and well documented code, however, and although it may seem strange, I have not been able to find out where the value of "refreshAll" is changed from "false" to "true" and vice versa.
Could you give me a clue?
Thank you and excuse my ignorance,
Post Number:#2 Post Mon May 27, 2019 3:30 pm
Images: 280
Solve rating: 219
Try search by (true) or (false) in all files.
The argument is passed in a function to say when the menu should be completely updated.
On setup you will find something like this:
mainScreen(true);
Post Number:#3 Post Tue May 28, 2019 3:54 am
Topics: 5
Topics: 5
I have noticed that the statement of the "refreshAll" argument is in the declaration of the functions although I still do not know where the change between "true" and "false" is decided, I suppose it will be with a timer.
Thank you and greetings
Post Number:#4 Post Tue May 28, 2019 10:41 am
Images: 280
Solve rating: 219
The statement is passed as argument to a function.
Example:
void mainScreen(bool refreshAll = false)
Here the variable refreshAll is declared as false by default.
This is a variable LOCAL it doesn't exists out of this function.
If you try change the value in some place of the code like this:
refreshAll = true;
You will get a compiling error:
Variable refreshAll not declared in scope.
To change the value of this variable you should pass the value as argument.
mainScreen(true);
Here you can see how it's used on code.
Check this article to learn more.
https://www.learncpp.com/cpp-tutorial/7 ... reference/
