Forum Software Ferduino code ATO and Pwc for Freshwater ?
Post Number:#1 Post Sun Jun 23, 2019 4:14 pm
Portugal
Hi
I am almost ready to mount my ferduino in my aquarium most functions i want i have been able to sort out ( with help from Fernando)
My last step is making me very confused.
I want to to ATO and PWC from the same reservoir using the same pumps. Seeing i have a freshwater tank this is enough for me.
Can anybody suggest how this can be done?
Thank You
Marco
Post Number:#2 Post Sun Jun 23, 2019 5:28 pm
Images: 278
Solve rating: 218
You should edit this part to make the sequence in PWC according to your setup.
The function for ATO is here.
Post Number:#3 Post Wed Jun 26, 2019 2:57 pm
Portugal
Post Number:#4 Post Wed Jun 26, 2019 3:25 pm
Images: 278
Solve rating: 218
The function is activated only via menu.
It won't work for you unless your setup is exactly like this:
I have explained this functions many times on forum, Take a look at:
viewtopic.php?f=8&t=308
viewtopic.php?f=8&t=73
If you did your custom function let me see your code.
Also you can add this debug messages on loop after LOGLN(FreeStack()); to see the status of each sensor and pump.
       LOG(F("Sensor 1: "));
       LOGLN(myAnalogRead(A0));
       LOG(F("Sensor 2: ");
       LOGLN(myAnalogRead(A1));
       LOG(F("Sensor 3: "));
       LOGLN(myAnalogRead(A2));
       LOG(F("Sensor 4: "));
       LOGLN(myAnalogRead(A3));
       LOG(F("Sensor 5: "));
       LOGLN(myAnalogRead(A4));
       LOG(F("Sensor 6: "));
       LOGLN(myAnalogRead(A5));
       LOG(F("marcadoriniciotpa: "));
       LOGLN(marcadoriniciotpa);
       LOG(F("shiftedmillis: "));
       LOGLN(shiftedmillis);
       LOG(F("Duration for stage: "));
       LOG(tempo/60000);
       LOGLN(F(" minutes"));
       if (PCF8575.digitalRead(bomba1Pin)==HIGH)
       LOGLN(F("Pump 1: ON"));
       LOGLN(F("Pump 1: OFF"));
       if (PCF8575.digitalRead(bomba2Pin)==HIGH)
       LOGLN(F("Pump 2: ON"));
       LOGLN(F("Pump 2: OFF"));
       if (PCF8575.digitalRead(bomba3Pin)==HIGH)
       LOGLN(F("Pump 3: ON"));
       LOGLN(F("Pump 3: OFF"));
Post Number:#5 Post Thu Oct 03, 2019 8:32 pm
Images: 278
Solve rating: 218
Have you solved the problem?
