Hi guys!
I'm happy to become part of this fantastic community. I think that Fernando and the whole team did a great job!
I'm designing a new aquarium and I would like that Ferduino will be the real beating heart of the whole system.
If I found out a used controller... I will need to realize some connections.
Let's start from a relays board. This one could be ok?
https://www.plexishop.it/it/modulo-rele-16-canali.html
Using that one, what i should do will be justo to buy something like this:
https://it.aliexpress.com/item/D-SUB-DB ... a4a452f934
and perform right connection on the DB25 connector? that's right?
for temperature sensor, can i buy a AS18B20 classic sensor and buy this one for connecting sensor to Ferduino?
https://www.plexishop.it/it/adattatore- ... -vite.html
Finally, for level sensor, is this one ok?
https://www.plexishop.it/it/sensore-di- ... quidi.html
which kind of connector there is on Ferduino for level sensor? which adapter can I buy for making the connection between sensors and board easy as Fernando thought?
thank you so much!
