Forum Latest news News Clouds and lightnings simulation
Post Number:#1 Post Mon May 01, 2017 3:33 pm
After some requests I have added code for clouds and lightnings simulation.
The code is available on Github.
Here a video:
The configuration for this function can be done only via web interface or directly on code.
Suggestions to improve the function are welcome.
Post Number:#2 Post Fri May 05, 2017 10:42 am
Indonesia
Post Number:#3 Post Sat May 06, 2017 3:23 pm
The best solution is install an ethernet shield to use other features available in web interface but if you don't want....
Look for this part: https://github.com/FernandoGarcia/Ferdu ... a.ino#L582
Mainly:
boolean desativarNuvemCanal[NUMERO_CANAIS] = {false, false, false, false, false, false};
byte probNuvemRelampago[2] = {100, 99}; // [0]= nuvem, [1] = relâmpago
byte quantDuracaoMinMaxNuvem[4] = {1, 10, 2, 9}; // Quant. mín., quant. máx., duração min., duração máx.
boolean desativarRelampagoCanal[NUMERO_CANAIS] = {true, true, true, true, true, true};
byte duracaoMinMaxRelampago[2] = {1, 5}; // Duração min., duração máx.
Post Number:#4 Post Fri Jun 02, 2017 2:27 pm
Indonesia
Mainly:
thanks fernando, If i want to try, whether using the "all led testing" feature, this function can work, so I do not have to wait long to see the results.
thanks
diztly wardizt
Post Number:#5 Post Tue May 15, 2018 8:09 am
Indonesia
thanks fernando is work very fine...
-------------------------------- Last edited Tue May 15, 2018 6:19 pm --------------------------------
sorry sir...i need your help
in cloud condition min and max, i need led is pwm min is '"0" and condition max is "255", i try to change this code but, result fail.
void executeRelampago(byte i)
  myAnalogWrite(pinoLED[i], random(pwm_nuvem[i], 126)); // Pequena oscilação
  delay(random(25, 75));
  myAnalogWrite(pinoLED[i], random(126, 175)); // Pequena oscilação
  delay(random(25, 50));
  myAnalogWrite(pinoLED[i], 0); // Luz media ===> 126 change to 0
  delay(random(50, 100));
  myAnalogWrite(pinoLED[i], 255); // Luz alta
  delay(random(100, 200));
  myAnalogWrite(pinoLED[i], pwm_nuvem[i]); // Luz normal
#ifdef USE_EXTRA_CHANNEL_FOR_LIGHTNING_DURING_NIGHT
  if ((relampagoNoturno == true) && (i == EXTRA_CHANNEL_FOR_LIGHTNING))
    myAnalogWrite(pinoLED[i], valorAnterior);
#endif
Return to News
Users viewing this topic: No registered users and 12 guests
