I have problems to run the serial port 1 hardware with the code ferduino
whether the use without ferduino uploaded works
I added this to the setup screen
Code: Select all
Serial1.begin(9600);   //inizializza seriale 1
delay (2000);
then if I send a command like this or any command
Code: Select all
Serial1.println("AT+CMGF=1\r");
 delay(1500);
 Serial1.println("AT+CMGS=\"xxxxxxxxxx\"\r");
 delay(1000);
 Serial1.println("message");
 delay(1000);
 Serial1.write(0x1A);
does not work
if I try to load only the test code works perfectly
along with ferduino code does not work
thank you
Portal Forum
Forum Login
Login Register
Register Search
Search Contact
Contact Images
Images Videos
Videos Web Control
