Forum Software Ferduino code Touch problem
Touch problem  [SOLVED]
Post Number:#41 Post Fri Feb 03, 2017 4:43 pm
Contact the seller.
Post Number:#42 Post Fri May 24, 2019 4:31 pm
Hi. Raul, has it finally been solved?
I am thinking of changing the screen for a nextion enhanced NX8048K070. The ITDB02-3.2WD has been removed from the market.
Fernando is it possible to use the nextion screen?
#define CAL_X 0x0045CFBBUL
#define CAL_Y 0x039FC143UL
#define CAL_S 0x8018F0EFUL
Whit this code in UtouchCD.h all work correct. Tanks
Post Number:#43 Post Fri May 24, 2019 9:40 pm
Try this coordinates
#define CAL_X 0x00430ED8UL
#define CAL_Y 0x002A0EECUL
#define CAL_S 0x000EF18FUL
and uncomment this line on code
#define INVERT_TOUCH
You can buy another TFT here yet.
Yes, if you are able to rewrite ALL the code to make it compatible.
Users viewing this topic: MSIE [Bot] and 1 guest
