Post Number:#281 Post Thu Dec 03, 2015 1:27 am
new ISO board build, designed by Fernando.
Board printed by OSHpark.com.
Board built by Christopher Kindig. (with help) ;)
It connects to the stamps and pins 14,15,16,17 to isolate power to each stamp and make the readings stable.
More common used when using EC probe.
-------------------------------- Last edited Wed Dec 02, 2015 10:31 pm --------------------------------
Building the ISO one circuit at a time and test as I go.
-------------------------------- Last edited Wed Dec 02, 2015 10:33 pm --------------------------------
Completed ISO circuit running on my system.
-------------------------------- Last edited Wed Dec 02, 2015 10:37 pm --------------------------------
screen on controller showing new readings for ISO, Ph, ORP and Specific gravity all stable and correct.
-------------------------------- Last edited Wed Dec 02, 2015 10:39 pm --------------------------------
Joy reef screen shot showing readings.
-------------------------------- Last edited Wed Dec 02, 2015 10:46 pm --------------------------------
this is one of my favorite parts of the tank, green zoanthid colony, my hammer coral and, a small blue berry patch corral.
Post Number:#282 Post Thu Dec 03, 2015 4:46 pm
Hi Fernando can 12 volt be applied to the brown and brown and white wires with out damage to the board?
Post Number:#283 Post Thu Dec 03, 2015 6:06 pm
Yes, but I can see a good reason for it. Mainly because there no GND in RJ45.
The VIN is connected on 5V regulator so, is better use power jack directly.
Post Number:#284 Post Fri Dec 04, 2015 2:29 am
Post Number:#285 Post Fri Dec 04, 2015 12:47 pm
I don't understand.
Using 12V in power jack you will get this voltage in RJ45 so, using 6V in power jack you will get this voltage in RJ45 too and so on.
Post Number:#286 Post Fri Dec 04, 2015 8:35 pm
Post Number:#287 Post Fri Dec 04, 2015 9:49 pm
Post Number:#288 Post Fri Dec 04, 2015 10:52 pm
Yes okay, but that is where you are saying to apply 12v and I will have 12v available on other components like the dosing pumps?
Post Number:#289 Post Fri Dec 04, 2015 10:59 pm
If you have the board powered with 12V, this voltage will be available on connector DB25 on pins called V = VIN. You can use this 12V to supply the relay board.
Post Number:#290 Post Sat Dec 05, 2015 3:35 pm
Hi Fernando, I went back and checked all of talks saw that, I am going to try it today with the old board and verify that does what I need it to do. I did check the voltage and it goes through at 12.8 volts should be okay.
Post Number:#291 Post Sat Dec 05, 2015 4:37 pm
Post Number:#292 Post Sat Dec 05, 2015 6:02 pm
Post Number:#293 Post Sat Dec 05, 2015 9:38 pm
Are you using a fan to cooling the heatsink?
Post Number:#294 Post Tue Dec 08, 2015 2:15 pm
Post Number:#295 Post Tue Dec 08, 2015 2:56 pm
Because it's important when using more than 9V.
Post Number:#296 Post Tue Dec 08, 2015 4:35 pm
Post Number:#297 Post Tue Dec 08, 2015 5:02 pm
When you was testing with 12V power supply, you was using a fan to cooling the heatsink and regulator?
Post Number:#298 Post Wed Dec 09, 2015 4:56 am
Yes and even then the network issue started right away, have you completed a board for the wave makers yet?
Post Number:#299 Post Wed Dec 09, 2015 12:35 pm
It's strange because I did test using 12V on this board without any issue.
I have the project for Jebao pumps, you can see here: viewtopic.php?f=24&t=40
Post Number:#300 Post Thu Dec 10, 2015 12:38 am
Users viewing this topic: No registered users and 14 guests
