Forum Members section DIY Ferduino controller TFT 800 X 600 - 7"
TFT 800 X 600 - 7"  [SOLVED]
Post Number:#1 Post Mon Oct 19, 2015 9:13 am
Images: 38
Hello Mr Garcia
We (I and my friend) have started a new Project in my reef (800 L) with FERDUINO Project to controller all the tank.
But a need you help with TFT!!!!
Your project user TFT 3.2" but I bought TFT 7" and we have a problem to installation, because the TFT screen no shows the information of calibration only white screen.
We are using your electrical diagram for installation at the components step by step.
We can to send information to explain with more detail or photos to stage that we stopped.
Post Number:#2 Post Mon Oct 19, 2015 10:23 am
Welcome Rafael!
I don't know any TFT with resolution of 800 x 600.
Post Number:#3 Post Mon Oct 19, 2015 11:40 am
Images: 38
Sorry resolution is 800x480.
Post Number:#4 Post Sun Oct 25, 2015 1:11 am
check Dale's build thread I believe he has a 7" tft display.
Post Number:#5 Post Sun Oct 25, 2015 9:00 am
In fact the code for 7" was done by Willie.
The topic is here: viewtopic.php?f=18&t=35
Post Number:#6 Post Sun Oct 25, 2015 4:08 pm
yes Willie sorry for the mix up I was trying to remember who did it, Thanks Fernando.
Post Number:#7 Post Tue Oct 27, 2015 11:17 pm
Images: 38
Hi!!! Fernando
I verified the topic by Willie which you suggested but yet I'm with the same problem (white screen).
In bellow any pictures of the Arduino Installation
White Screen
TFT installation based in your schematic electric Led_A Installation with 1 resistor
53 pin to 5 pin
53 pin to 10 pin
TFT schematic 7" - Do you suggest I use this?
Best Regards
Post Number:#8 Post Tue Oct 27, 2015 11:33 pm
I am not sure I fixed my white screen issue by accident, and can not remember what I did to resolve it. I do know I had had to go by the schematics for the screen, I have the same shield as well so at this point I would say use the schematics and verify voltage and grounds. Have you down loaded hennings lib for tft? it can be found here
Post Number:#9 Post Wed Oct 28, 2015 7:35 am
Images: 38
Thanks Christofer
What is the libraries I need to download?
Post Number:#10 Post Wed Oct 28, 2015 8:18 am
Utft and utouch
Post Number:#11 Post Wed Oct 28, 2015 9:44 am
I can see many things wrong here.
1 - In Willie's topic have a link to his Github where you can download the code with all libraries. https://github.com/willie111/Feduino_wi ... 7_Joy_Reef
2- To start connect the TFT directly on TFT shield and Arduino without anything else.
Post Number:#12 Post Wed Oct 28, 2015 10:28 am
Hi Fernando. I remember when went through this same thing the way I fixed was as you suggested with those two library from Karl henning site, or have they changed somthing?
And yes I agree just the screen on the shield was one step we had.
Post Number:#13 Post Wed Oct 28, 2015 9:19 pm
Images: 38
Hello Guys
I downloaded the all file from Willie.
But I didn't have success, because the code have "error"
Started with calibration but error
I try to change the code CTE70 and pins 7,6,5,4,3 but error
And other try I put de complete code, but error
Post Number:#14 Post Wed Oct 28, 2015 9:49 pm
1 - I told here 1 TON of times to use IDE 1.0.6.
2 - The pins for touch are 6,5,4,3,2.
-------------------------------- Last edited Wed Oct 28, 2015 9:52 pm --------------------------------
The problem is other, the users have problems by do not pay attention in my instructions.
In 1 download have all files needed.
Post Number:#15 Post Wed Oct 28, 2015 11:11 pm
Okay I see. What did they change on the new ideas or do we just know it doesn't work?
Post Number:#16 Post Thu Oct 29, 2015 7:33 pm
Images: 38
Hello Guys
Thanks your help.
UTouch Calibrations OK but the complete code NOK
What are the error now?
Post Number:#17 Post Thu Oct 29, 2015 8:58 pm
Use UTFT library downloaded with Willie's code.
Post Number:#18 Post Sat Oct 31, 2015 12:08 am
Images: 38
Hi Fernando
Today I'm very happy :D :D because I had my first success. But only one!!!! :| :|
I could calibrate the TFT and execute the examples "UTFT_Demo_800x480".
After then I tried UTOUCH_Button Test, but the TFT code was ITDB32S,
So I changed it to CTE70 and request verification
The Arduino changed CTE70 for ITDB32S and some errors
Could you help me?
PS: All the test I use Willie's code
Post Number:#19 Post Sat Oct 31, 2015 11:06 am
Are 2 tabs with code equal opened. Close one.
Post Number:#20 Post Thu Nov 05, 2015 12:17 pm
Canada
I want to know the specifications of the TFT you are using based on its current and voltage characteristics.
Also which interface it uses with the board?
Can you please tell me which other displays are compatible with this board?
