Forum Members section Show your controller Lucas' Ferduino DIY
Lucas' Ferduino DIY
Post Number:#1 Post Tue May 26, 2015 7:50 pm
My parts have all arrived so it's time to get started building.
I am going to start with the main Ferduino unit. When I have some more money available, I will add LEDs/Drivers/Fans, Dosing Pumps, pH Probe, etc. My tank is 120g so LED prices add up fast.
Here are the parts:
- Mega
- ULN2803
- Protoshield
- Screen
- TFT
- Ethernet
- Temperature
- PCF8575
- 16 Channel Relay
- Cat5 Cable, Couplers, and Crimper
- Various Jumpers
- Power supply from an Arduino Uno kit I had laying around
Here is how far I have gotten so far. :p
Only two questions so far:
1. There is a switch on the Ethernet Shield that says "5v or 3V3". Which should it be set to?
2. What type of solder is best for this project?
Post Number:#2 Post Wed May 27, 2015 10:37 am
Have a problem with this ethernet shield.
It haven't the ICSP header on bottom side like this:
So the SPI BUS is unplugged.
You need use wires to connect it as you did to pin 10 and 53.
See the pins to make the bridge:
Ethernet shield:
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK).
Arduino Mega 2560:
SPI: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (SS).
The Arduino works with 5V.
Are you talking about tin wire?
