Forum Members section DIY Ferduino controller Dosers calibration resetting
Dosers calibration resetting  [SOLVED]
Post Number:#1 Post Wed May 27, 2015 4:54 am
Topics: 11
Topics: 11
I have found a problem with my controller. I have calibrated the dosers and then done a manual dose and it works. But then I'd the controller resets and I do a manual dose, it comes up with thousands of seconds on journey and overdoses massively. If I then go to calibration all the values are correct and I click save and it works again until resetting again.
Also, if I configure and save on journey but then do a manual dose on the controller itself then I get the same problem. It has to be saved on both journey and the controller after every reset to function correctly.
I want to set them up on a custom setting so I don't have to manual but I don't trust that it will work properly if something causes a reset etc.
Post Number:#2 Post Wed May 27, 2015 10:27 am
This problem was fixed 21 days ago :)
Check this:
https://github.com/FernandoGarcia/Fedui ... a9be0f3fae
Post Number:#3 Post Wed May 27, 2015 4:51 pm
Topics: 11
Topics: 11
brill, thanks
