Forum Software Ferduino code Problem with SD Card on ITDB32WD
Problem with SD Card on ITDB32WD  [SOLVED]
Post Number:#1 Post Sun Apr 26, 2015 2:55 am
Columbia
Hi.
I have a ITEAD ITDB32WD with SD card reader built in, I have a problem reading from this. When I run the program Sdinfo the result is
SdFat version: 20120825
type any character to start
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
What is damage in this card reader?
best reagrds
Last edited by Fernando Garcia on Sun Apr 26, 2015 9:55 am, edited 1 time in total.
Reason: Spelling.
Post Number:#2 Post Sun Apr 26, 2015 10:01 am
Are you using an ethernet shield?
Try use an example available on forum and change the chipselect to 53 if you are not using an ethernet shield.
Post Number:#3 Post Sun Apr 26, 2015 11:52 am
Columbia
No, I'm not using an ethernet shield, I'm using this TFT http://store.iteadstudio.com/index.php?main_page=product_info&cPath=57_58&products_id=263
I have trying with the examples changing the chipselect to 53 but nothing.
Post Number:#4 Post Sun Apr 26, 2015 12:01 pm
The card was formatted?
What's the capacity of this card?
Post Number:#5 Post Sun Apr 26, 2015 8:35 pm
Columbia
Yes, the card was formatted (whith mac osx format FAT 16) and with windows pc. I used two memories: 128MB and 2GB.
Post Number:#6 Post Mon Apr 27, 2015 10:19 am
Using the card of 2 GB try change on setup:
card.init(SPI_HALF_SPEED, SelectSlave_SD);
card.init(SPI_QUARTER_SPEED, SelectSlave_SD);
Or:
card.init(SPI_FULL_SPEED, SelectSlave_SD);
Post Number:#7 Post Tue Apr 28, 2015 8:09 pm
Columbia
Using this
void loop() {
  // read any existing Serial data
  while (Serial.read() >= 0) {}
  // pstr stores strings in flash to save RAM
  cout << pstr("\ntype any character to start\n");
  while (Serial.read() < 0) {}
  uint32_t t = millis();
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!card.init(SPI_FULL_SPEED, SdChipSelect)) {
    sdErrorMsg("\ncard.init failed");
    return;
The result is
card.init failed
SD errorCode: 0X1
SD errorData: 0XFF
That can I do?
Regards
Last edited by Fernando Garcia on Wed Apr 29, 2015 10:43 am, edited 1 time in total.
Reason: Please use tags [code][/code] to post any code here.
Post Number:#8 Post Wed Apr 29, 2015 10:45 am
As I told use the examples available on forum.
Check the soldering of your TFT shield.
Post Number:#9 Post Fri May 01, 2015 11:39 am
Columbia
Thenk but now the arduino show this:
MemoMemoria livre: 6855
Erro: vol.init Falhou!
SD Erro: 4,FF
Post Number:#10 Post Fri May 01, 2015 1:07 pm
It should be problem with hardware.
Post Number:#11 Post Fri May 01, 2015 10:54 pm
Columbia
Apparently it was a solder and pin.
Problem resolve.
Regards
Users viewing this topic: SEMrush [Bot] and 1 guest
