it is possible to download an earlier version of ferduino french master ?
I explain
in November I tested a version that worked perfectly with my material , and following a bad manipulation
 I have redeemed all material ( arduino mega , screw shield teak rak , tft shield itead itbd02 2.1 tft lcd screen itead 240x400)
  I have redeemed all material ( arduino mega , screw shield teak rak , tft shield itead itbd02 2.1 tft lcd screen itead 240x400) I downloaded the latest version of the installation ferduino this property passes everything works except rct .
the manufacturer of screw shiel said: @ The shield of Pins which are connected the RTC are 21 and 22 (SDA and SDL ) . Removing the battery does not stop the operation of the RTC , it is used only for backup in case of power failure .
I ' tried to connect over the screw sield the V1.1 itbd02 and rct work.
Portal Forum
Forum Login
Login Register
Register Search
Search Contact
Contact Images
Images Videos
Videos Web Control
