Forum Software Ferduino code Shortcut on main screen to manual timer
Shortcut on main screen to manual timer  [SOLVED]
Post Number:#1 Post Wed Jul 23, 2014 2:45 am
Hi Fernando !! :-h
Can you help me for create touch shortcut on main screen (timer print) to make manual on or off timer 1.
Because the touch process is too difficult for me.
This feature allows you to manually feed the fish, which is a real pleasure to see them eat.
Thanks you in advance.
Sueur Aurelien
Post Number:#2 Post Wed Jul 23, 2014 10:11 am
You want skip to this menu?
Post Number:#3 Post Thu Jul 24, 2014 4:00 pm
I want when I touch the area with the red outline, it disables the function timer 1 10 min.
after for my skimmer I should conbiner function timer 2 with timer1:
When timer 1 if off -> timer 2 is off
When timer 1 go on -> timer 2 go on After 60 second.
thank you for your help
Post Number:#4 Post Thu Jul 24, 2014 4:32 pm
You can make it using a method very simple.
Add in ferduino tab:
unsigned long interval_feed_millis = 0;
int interval_feed = 10; // in minutes
boolean feed_mode = false;
Add on loop:
if(feed_mode == true)
  if((millis() - interval_feed_millis) > (interval_feed*60000))
    feed_mode = false;
    ler_timers_EEPROM();
in ProcessyMyTouch find:
    case 0:                       //Tela de inico
      dispScreen=30;
      clearScreen();
      solicitar_senha();
      break;
Replace with:
      if(((x > 0)  &&  (x < 399)  &&  (y > 0)  &&  (y < 138)) || ((x > 128) && (x < 399) && (y >= 138) && (y < 239)))
        dispScreen=30;
        clearScreen();
        solicitar_senha();
        break;
        feed_mode = true;
        interval_feed_millis = millis();
        temporizador_1_ativado = 0;
        temporizador_2_ativado = 0;
Post Number:#5 Post Thu Jul 24, 2014 4:52 pm
Fernando you are very impressive ^:)^
thank you very much, i test it.
Post Number:#6 Post Thu Jul 24, 2014 5:17 pm
