Hi Fernado
is it possible to add a menu command to pump Jebao DC series in PWM, because it has the same order as wave maker ?
Thank you in advance
Best Regard.
Aurelien Sueur
UTouch myTouch(6,5,4,3,2);
if(modo_selecionadoDC == 1)
PumpDCPWM = 255;
else if(modo_selecionadoDC == 2)
PumpDCPWM = 127;
else if(modo_selecionadoDC == 3)
PumpDCPWM = 63;
// No need add it if you will use pins already declared on code
const byte sensor_skimmer = analog pin free;
const byte skimmerPin = free pin;
pinMode(sensor_skimmer, INPUT);
pinMode(skimmerPin, OUTPUT);
void check_level_skimmer()
if(analogRead(sensor_skimmer) > 400)
digitalWrite(skimmerPin, LOW);
digitalWrite(skimmerPin, HIGH);
} check_level_skimmer();
