Forum Software Ferduino code Ato problem
Ato problem  [SOLVED]
Post Number:#1 Post Thu Sep 12, 2019 7:40 pm
Images: 5
Hi Fernando!
A strange thing happened to me. I am testing the cooler and I noticed that when it is working the ato does not go. As soon as the chiller turns off the ato starts again. No problem when the heater is in operation. Can you help me ?
Post Number:#2 Post Thu Sep 12, 2019 9:24 pm
This not a problem it's a feature.
Since there's possibility to happen a leak while chiller is working the ATO function is ignored to prevent fill all the tank with freshwater.
You can see all conditions here:
void reposicao_agua_doce () // abre a solenoide 1 se o nível estiver baixo e se a tpa não estiver em andamento
// e se o chiller estiver desligado e se o nível do sump não estiver anormal e se não houve falha durante uma tpa.
    if ((analogRead(sensor3) > 400) && (analogRead(sensor2) > 400) && (bitRead(tpa_status, 1) == false) && (bitRead(status_parametros, 0) == false) && (bitRead(tpa_status, 2) == false))
      PCF8575.digitalWrite(solenoide1Pin, HIGH);
      bitWrite(Status, 1, 1); // sinaliza reposição em andamento
      PCF8575.digitalWrite(solenoide1Pin, LOW);
      bitWrite(Status, 1, 0);
