Forum Software Ferduino code Change the pins for timers and skimmer
Change the pins for timers and skimmer  [SOLVED]
Post Number:#1 Post Thu Jul 05, 2018 2:53 pm
In my Ferduino there are left the pins 46, 48, 59, 66, 67, 68 and 69; Is it possible to use these pins to control the skimmer, fresh water pump and the 5 timer outlets?
If yes, what should I change in the code to effect these changes, if possible I will not need to use the PCF5875.
Rômulo
Post Number:#2 Post Thu Jul 05, 2018 4:04 pm
Just swap the pin numbers.
Example:
const byte wavemaker2 = 46;
const byte temporizador1 = 80;
Change to:
const byte wavemaker2 = 80;
const byte temporizador1 = 46;
