Forum Software Ferduino code Doubt about DHCP and IP
Doubt about DHCP and IP  [SOLVED]
Post Number:#1 Post Sat Jun 23, 2018 2:30 pm
I do not understand network settings, and I use a modem with wi fi connection and a router to boost the wi fi signal on a homemade cable internet network. In this case I have to enable the DHCP command line?
// Comment this line to use static IP.
// # define USE_DHCP // Uncheck this line to use DHCP
Another question, in these lines below do I have to change some configuration? Or do I keep everything as it is?
#ifndef USE_ESP8266 //Do not change this line
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Este MAC deve ser único na sua rede local.
byte ip[] = {192, 168, 0, 177};                     // Configure o IP conforme a sua rede local.
IPAddress dnsServer(8, 8, 8, 8);                    // Configure o IP conforme a sua rede local. Este é o DNS do Google, geralmente não é necessário mudar.
IPAddress gateway(192, 168, 0, 1);                  // Configure o "Gateway" conforme a sua rede local.
IPAddress subnet(255, 255, 255, 0);                 // Configure a máscara de rede conforme a sua rede local.
Rômulo.
Last edited by Fernando Garcia on Sat Jun 23, 2018 3:53 pm, edited 1 time in total.
Post Number:#2 Post Sat Jun 23, 2018 3:52 pm
There's nothing to change on code when using WiFi.
The meaning of this line:
#ifndef USE_ESP8266
Is: If not defined USE_ESP8266
In others words if not using ESP8266 then...
You should set static IP in router settings.
