Forum Software Ferduino code Sensor4 - level sensor
Post Number:#1 Post Fri Feb 09, 2018 4:29 pm
Images: 8
I'm testing the level sensors but I can not understand the use of level 4. reading the code I seemed to have understood that it was used to measure the low level in the tank to restore the evaporated water in order not to burn the pump. unfortunately I think I did not understand. I'm trying the sensor4 but the pump is not controlled by the sensor4.
this function would be for useful. can you help me?
Last edited by Fernando Garcia on Fri Feb 09, 2018 5:39 pm, edited 1 time in total.
Reason: Fix typo
Post Number:#2 Post Fri Feb 09, 2018 5:40 pm
Sensor 4 is used for partial water change only.
Check the schematic:
Post Number:#3 Post Sat Feb 10, 2018 5:40 am
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=413
halow bro...whether the mode of water change does not conflict with evaporation condition, because there is same sensor for a reference.
