Forum Software Ferduino code Pumps pin
Pumps pin
Post Number:#1 Post Tue Feb 06, 2018 7:34 pm
Images: 8
hello fernando,
I'm a bit 'confused about the use of the bomba1, bomba2, bomba3.
unfortunately I can not understand the translation well.
I need to connect the return pump. I think I understand that the bomba1 is for to restore the evaporated water (controlled by sensor2 and sensor3).
I have connected the pump pins to the relay but bomba2 and bomba3 remains switched off. could it be that they do not come on because I have not yet installed all the level sensors?
Post Number:#2 Post Tue Feb 06, 2018 7:51 pm
As I told before this pumps are for partial water change (PWC).
I think you should search for ATO.
Look for "void reposicao_agua_doce ()" function on code.
The pin used is: solenoide1Pin
Post Number:#3 Post Tue Feb 06, 2018 7:54 pm
Images: 8
Post Number:#4 Post Tue Feb 06, 2018 8:00 pm
There's no control for return pump.
