Forum Software Ferduino code Question: automatic filler, ambient Tª sensor and skimmerr
Question: automatic filler, ambient Tª sensor and skimmerr  [SOLVED]
Hello everyone.
Sorry for my English
I´m making a marine controller, version May 2017 and IDE 1.8.1.
My questions are:
1- Which pins should I use for the automatic filler?, ¿Pin 55(A1) lower sump level, Pin 56(A2) upper level sump, Pin 57(A3) lower level deposit and Pin 62(A8) sump pump?
I do not want to use automatic partial water change, I just want to fill the evaporated water.
2- I want to control a fan with the ambient temperature sensor, in the same way the LED display temperature sensor controls the fans. How can I do it?
3- How does the pin 87 (skimmer) work?
Thank you and best regards.
Welcome Fernando!
1 - I have explained how ATO function work several times here.
Look for this topic: viewtopic.php?p=373#p373
For ATO you will use only sensor 2 and 3 that are pins A1 and A2. The conditions are here: https://github.com/FernandoGarcia/Ferdu ... s.ino#L425
2 - You can work with the variable tempA doing someting like this:
if(tempA > xx.xx)
    do it!
else if(tempA < yy.yy)
   do whatever...
   do anything...
3 - Turns off the skimmer when the level on sump is very high to prevent overflow. Check the code here: https://github.com/FernandoGarcia/Ferdu ... s.ino#L495
P.S. Pin numbers higher than 69 are fake.
Thank you, Fernando. I'll look. A greeting.
