Forum Software Ferduino code Problem serial1
Problem serial1
Post Number:#1 Post Sun Feb 19, 2017 12:54 pm
Topics: 22
Topics: 22
hello fernando
I have problems to run the serial port 1 hardware with the code ferduino
whether the use without ferduino uploaded works
I added this to the setup screen
Serial1.begin(9600);   //inizializza seriale 1
delay (2000);
then if I send a command like this or any command
Serial1.println("AT+CMGF=1\r");
 delay(1500);
 Serial1.println("AT+CMGS=\"xxxxxxxxxx\"\r");
 delay(1000);
 Serial1.println("message");
 delay(1000);
 Serial1.write(0x1A);
does not work
if I try to load only the test code works perfectly
along with ferduino code does not work
Post Number:#2 Post Sun Feb 19, 2017 2:52 pm
Where's connected your RTC?
Post Number:#3 Post Sun Feb 19, 2017 4:45 pm
Topics: 22
Topics: 22
rtc is connected to Pin 20 21 scl and sda
the Serial1 on pin 18 19
but I've also tried with Serial2, 3
but it does not work
does not send commands
Post Number:#4 Post Sun Feb 19, 2017 5:16 pm
If this variable is commented it should work.
#define USE_PINS_18_AND_19_FOR_RTC
Serial 2 and 3 are used for stamps.
If it doesn't work I have no idea about the reason and I haven't hardware (GSM module) to make tests.
Last edited by Fernando Garcia on Sun Feb 19, 2017 6:27 pm, edited 1 time in total.
Reason: Fix typo
