Forum Software Ferduino code White TFT with Ferduino
White TFT with Ferduino  [SOLVED]
Post Number:#1 Post Mon Dec 19, 2016 4:48 pm
I'm doing some test with the new Ferduino version. I've run the calibration test for my LCD and found that my lcd has mirroed coordinates.
I then run the test code for the lcd (the one with the number and the one that Fernando has posted on the forum) Both work perfectly.
When I try to upload Ferduino everything goes well but I have a white screen. Even opening the serial monitor I couldn't see anything.
It semms like the program isn't running...
What can I try to do?
thank you very much!
Post Number:#2 Post Mon Dec 19, 2016 5:01 pm
Comment the variable "USE_PCF8575".
Post Number:#3 Post Mon Dec 19, 2016 5:36 pm
Now it works thank you!
Post Number:#4 Post Mon Dec 19, 2016 5:48 pm
Save your time use the search.
I found the answer on first result: viewtopic.php?f=8&t=374&p=2886&hilit=white+screen#p2886
