Forum Software Ferduino code Only 1 sensor osmosi
Post Number:#1 Post Sun Dec 11, 2016 5:50 am
Topics: 22
Topics: 22
I would make topping up system of evaporated water with the use of only one float in sump
on temporary protection after 10 seconds if the sensor has not arrived to the off position you must stop the pump and trigger an alarm at the same time if the sesore returns off the first of 10 seconds must always stop the pump but without alarm
I did so but I do not work the time of 10 seconds
const byte sensorerabbocco = 49;
const byte pinrabbocco = 47;
boolean allarme_rabbocco = false;
unsigned long temporabbocco = 0;
tab setup
pinMode(sensorerabbocco, INPUT_PULLUP);
pinMode(pinrabbocco, OUTPUT);
tab loop
if (digitalRead (sensorerabbocco) == LOW)
   if (allarme_rabbocco == false)
      digitalWrite(pinrabbocco, HIGH);
            if (millis() - temporabbocco > 10000)
          digitalWrite(pinrabbocco, LOW);
          allarme_rabbocco = true;
          temporabbocco = millis();
Post Number:#2 Post Sun Dec 11, 2016 12:25 pm
Try this:
if (digitalRead(sensorerabbocco) == LOW)
    if (digitalRead(pinrabbocco) == LOW)
if (((millis() - temporabbocco) > 10000) && (digitalRead(pinrabbocco) == HIGH))
