Forum Software Ferduino code New Web code and screen lockup.
New Web code and screen lockup.  [SOLVED]
Post Number:#1 Post Wed Dec 07, 2016 5:34 am
Hello all, so after I uploaded the new code I had an issue.
Once the tft was touched the first time it would goto the first menu then no longer respond till I did a hard reset.
Just curious if anyone else may have strange things go on and what your results are. I am going to work more with the settings and code over the next few days and see if I can find the issue.
Post Number:#2 Post Wed Dec 07, 2016 9:43 am
Did you some change in this variables?
//#define USE_TFT_SHIELD
Default code should work with Ferduino Mega without changes of pins for SD card and touch screen.
Post Number:#3 Post Wed Dec 07, 2016 10:43 am
No sir I did not change any of these, I left them as default for ferduino, them added library UTFT driver file to arduino for my display just like in the past.
Post Number:#4 Post Wed Dec 07, 2016 11:50 am
Are you using your damaged Ferduino Mega for it?
Post Number:#5 Post Wed Dec 07, 2016 1:22 pm
No sir the good one, the other sets up like a shield I have been using it for other project with the wavemaker cotrol ed with i2c.
Post Number:#6 Post Wed Dec 07, 2016 3:40 pm
Have you checked the coordinates of your touch screen?
Maybe libraries were replaced and calibration too.
Post Number:#7 Post Wed Dec 07, 2016 4:47 pm
Yes, the files for touch are saved separately from all others and can not be deleted.
I used the watchdog setting and got it working again.
Post Number:#8 Post Wed Dec 07, 2016 4:57 pm
I don't understand, what happens with watchdog?
Post Number:#9 Post Wed Dec 07, 2016 5:25 pm
ferduino works with watchdog un-commented.
Post Number:#10 Post Wed Dec 07, 2016 9:28 pm
It should work without watchdog too.
Post Number:#11 Post Mon Dec 12, 2016 1:51 pm
Have you tested it again without watchdog?
Watchdog will restart the board when the code freezes if you have problem it will restart constantly.
Post Number:#12 Post Tue Dec 13, 2016 2:27 am
Yes and it is still the same I will see if I can find the issue tomorrow.
Post Number:#13 Post Tue Dec 13, 2016 3:02 pm
so till the same I am going to uncomment watchdog and reload the sketch and work with it for now.
Post Number:#14 Post Tue Dec 13, 2016 3:42 pm
I can't see reason for it.
Send me your full Ferduino code please.
Post Number:#15 Post Thu Dec 15, 2016 3:51 pm
how can I send it to you?
Post Number:#16 Post Thu Dec 15, 2016 4:36 pm
Can be on Skype or a link to One drive, Google drive or Dropbox.
Post Number:#17 Post Thu Dec 29, 2016 3:44 am
Lock up issue is solved.
Was problem with my pwm circuit for pump control.
  • Similar Topics
    Replies
    Views
    Last post
