Forum Software Ferduino code Image RAW to Ferduino Code
Image RAW to Ferduino Code  [SOLVED]
Post Number:#1 Post Thu Jun 23, 2016 12:04 am
fernando halo, can be given arduino code with image, with an extension of RAW.
I'm trying to practice arduino code to change the look of the display home with the image.
I tried it in the library added
"UTFT_SdRaw" library
in ferduino tab
// File system object
SdFat sd;
const byte ChipSelect = 53; // For TFT Shield
UTFT_SdRaw MyFiles (& myGLCD);
try to load a picture in the tab ferduino
// Draw home icon
   myFiles.load (0, 254, 240, 66, "filexxx.raw", 4);
but still errors
thanks
Post Number:#2 Post Thu Jun 23, 2016 11:20 am
I don't know this library, try this library called "UTFT_SdFat".
In Ferduino tab add only this lines:
#include "UTFT_SdFat.h"
UTFT_SdFat myFiles(&myGLCD);
Use this line to show the image:
myFiles.loadBitmap(26, 80, 188, 72, "image.raw");
BTW: When ask help about something show me the errors because I haven't a crystal ball.
Post Number:#3 Post Fri Jun 24, 2016 7:25 am
Topics: 22
Topics: 22
hello Fernando
I tried to use this library to display the images in .raw format, but the image is not displayed
this is the code I used
how to use the sd card integrated in the TFT display
I copied prova.raw image files with one resolution 150 * 150
in Ferduino TAB
#include <UTFT_SdFat.h>
onst byte SD_CARD = 0;
const byte ETHER_CARD = 1;
const byte RFM = 2;
const byte ChipSelect_SD = 53;
const byte SelectSlave_ETH = 4;
const int ChipSelect_RFM = A15;
UTFT        myGLCD(ITDB32WD, 38,39,40,41);   //"X" é o modelo do LCD
UTouch      myTouch(6,5,4,3,2);
//UTouch      myTouch(7,6,5,4,3);
tab inicio
myFiles.loadBitmap (251, 95, 150, 150, "prova.raw" ,1 );
but I see nothing
Post Number:#4 Post Fri Jun 24, 2016 1:04 pm
Try to make it work with example called "Load_image.ino" available in library folder.
If you have problem try "SPI_HALF_SPEED" or "SPI_QUARTER_SPEED" instead "SPI_FULL_SPEED"
Here a test I did using the image "TEST.RAW".
I won't test with Ferduino code because I don't want change my libraries folder for it.
Post Number:#5 Post Fri Jun 24, 2016 2:47 pm
Topics: 22
Topics: 22
I did the test that you suggested and loaded the example "Load_image.ino" works fine
I tried to add in ferduino code but does not load the wallaper
maybe I can not understand on what tab I have to write different code strings
Post Number:#6 Post Sat Jun 25, 2016 12:42 pm
It worked to me.
Ferduino tab:
L_Menu tab:
Result:
I'm using images from iAqua avalaible here.
Post Number:#7 Post Sat Jun 25, 2016 2:19 pm
Topics: 22
Topics: 22
I could not read the sd I added this code and it worked
in tab setup
myfile.begin(ChipSelect_SD, SPI_FULL_SPEED);
in tab ferduino
SdFat myfile;
now it works fine
I need more help
I wrote the code to display the images of the moon phase by loading them in the code in .c
in tab moonPhase
if ((AG >= 0) && (AG <= 1.85))         // 0 a 12.5%
    LP = tabela_textos_fase[1];         // "LUNA NUOVA"
    MoonPic = New_Moon;
  if ((AG > 1,85) && (AG <= 5.54))       //12.5% a 35.5%
    LP = tabela_textos_fase[2];        // "LUNA CRESCENTE"
    MoonPic = Waxing_Crescent;
  if ((AG > 5.54) && (AG <= 9.23))     //  37.5 A 62.5%
    LP = "   PRIMO QUARTO";               // "PRIMO QUARTO"
    MoonPic = First_Quarter;
  if ((AG > 9.23) && (AG <= 12.92))    //  62.5 A 87.5%
    LP = "GIBBOSA CRESCENTE";          //GIBBOSA CRESCENTE
    MoonPic = Waxing_Gibbous;
  if ((AG > 12.92) && (AG <= 16.61))      // 87,5 a 100 e da 100 a 87.5%
    LP = tabela_textos_fase[3];         // "LUNA PIENA"
    MoonPic = Full_Moon;
  if ((AG > 16.61) && (AG <= 20.30))   // 87.5 A 62.5%
    LP = " GIBBOSA CALANTE";             // GIBBOSA CALANTE
    MoonPic = Waning_Gibbous;
  if ((AG > 20.30) && (AG <= 23.99))    //62.5 A 35.5%
    LP = "  ULTIMO QUARTO";             //ULTIMO QUARTO
    MoonPic = Last_Quarter;
  if ((AG > 23.99) && (AG <= 27.68))     // 37,5 a 12,5%
    LP = tabela_textos_fase[4];         // "LUNA CALANTE"
    MoonPic = Waning_Crescent;
  if ((AG >= 27.68) && (AG <= LC))       //12.5 a 0%
    MoonPic = New_Moon;
  return phase;
in tab ferduino
unsigned int *MoonPic;
extern unsigned int
  New_Moon[0xD24],
  Waxing_Crescent[0xD24],
  First_Quarter[0xD24],
  Waxing_Gibbous[0xD24],
  Full_Moon[0xD24],
  Waning_Gibbous[0xD24],
  Last_Quarter[0xD24],
  Waning_Crescent[0xD24];
in this way it works fine
but I would like to load from sd pictures with the library UTFT_SdFat in order to free up space on the Arduino memory
but I can not get it to work you will give me a help?
Post Number:#8 Post Sat Jun 25, 2016 6:05 pm
This lines of code are not needed to my latest version of Ferduino.
Take the image and convert to .RAW using this online tool so use the code above to load the images.
Post Number:#9 Post Sun Jun 26, 2016 5:26 am
Topics: 22
Topics: 22
yes thank you to convert images in RAW I know him
but if I write me error code I do not understand where I'm wrong
ferduino tab
unsigned int *MoonPic;               //Pointer to the Lunar Phase Pics
extern unsigned int                 //Lunar Phase Pics
  New_Moon[0xD24] = myFiles.loadBitmap(7, 80, 200, 60, "newmoon.raw");
I can not figure out how to call up the image using pointer
Post Number:#10 Post Sun Jun 26, 2016 8:40 am
Topics: 22
Topics: 22
ferduino tab
I managed to solve correcting code
now it works fine
Post Number:#11 Post Mon Jun 27, 2016 3:28 am
thx all and fernando.
:-bd :-bd
is works fine.
go to hardwork to change visual display.
