Forum Software Ferduino code Combine output with two different input driver
Combine output with two different input driver  [SOLVED]
Post Number:#1 Post Fri Jun 17, 2016 1:06 am
Hallow everyone,
I need a solution to overcome the two drivers of different inputs in 1 controller.
1. This driver requires input HIGH to off
driver with HIGH to Off
2. while the mosfet driver using IRLZ44N use LOW to off.
i need 1 diver to invert output.
how to solve this problem.
Thankz
In the tab LEDs find:
    b_out = bled_out;
    w_out = wled_out;
    rb_out = rbled_out;
    r_out = rled_out;
    uv_out = uvled_out;
    moon_out = moonled_out;
Replace the line corresponding to the channel that you will use this driver by something like this:
    b_out = (255 - bled_out); // Blue
    w_out = (255 - wled_out); // White
    rb_out = (255 - rbled_out); // Royal blue
    r_out = (255 - rled_out); // Red
    uv_out = (255 - uvled_out); // UV
    moon_out = (255 - moonled_out); // Moonlight
Post Number:#3 Post Mon Jun 20, 2016 5:55 am
ok. thanks Verymuch.
:-bd :-bd
diztlyWardizt.
