Forum Software Ferduino code Compilation error
Compilation error
Post Number:#1 Post Fri May 13, 2016 9:54 pm
Mexico
Hi, I have my mega2560, mi w5100 shield, ds18b20, RTC3231, the test code for w5100 works ok
// Save this file on SD card as index.htm
Hello world!
This page is stored in a SD card plugged on Arduino
Visit my website: http://www.ferduino.com
Code adapted by Fernando Garcia
I want to use without LCD if I compile the code with TFT is ok
but when I cooment the 110 #use TFT line shows error
Arduino:1.6.7 (Windows 7), Placa:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Opciones de compilación cambiadas, reconstruyendo todo
In file included from H:\Dropbox\Arduino\ferduino\arduino-1.6.7\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from sketch\Ferduino_with_webcontrol_beta.ino.cpp:1:
C:\Users\0EE78~1\AppData\Local\Temp\arduino_5033178e2e503d3344c3ecaf7bc36632\Loop.ino: In function 'void loop()':
Loop:207: error: 'tabela_textos' was not declared in this scope
           strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[17])));
Loop:208: error: 'anT' was not declared in this scope
           printButton(buffer, anT[0], anT[1], anT[2], anT[3]); // tabela_textos[17] = "INICIAR"
Loop:208: error: 'printButton' was not declared in this scope
exit status 1
  Este informe podría tener más información con
  "Mostrar salida detallada durante la compilación"
  activala desde Archivo > Preferencias
Post Number:#2 Post Fri May 13, 2016 10:10 pm
I have fixed the code, please do this changes in your code:
https://github.com/FernandoGarcia/Ferdu ... 79b0694463
Post Number:#3 Post Sat May 14, 2016 1:43 am
Mexico
Nice, thanks fernando, I configured the local ip, the sd pin to 4, load the sketch but when I try to
validate settings in webserver the error
Connection timed out after 5000 milliseconds.
Your controller is not responding.
Please check your host address, port number and port forwarding in your router.
open the serial monitor and this is the text
Please insert a SD CARD
should I put files in the sd card? the card has the index file I used for the test code
Post Number:#4 Post Sat May 14, 2016 12:13 pm
Are you talking about this variable?
const byte ChipSelect_SD = 4
On setup try change this variable:
SPI_HALF_SPEED
SPI_QUARTER_SPEED
There no file to place on SD card.
